HellfireStudios
I know that styrene caps are finicky little buggers (alcohol and/or high heat can do them in), and I know they can be microphonic. I've heard that you can stabilize styrenes with hot glue to keep them from becoming microphonic. My concern is with the heat from the glue damaging the cap. Could superglue be used in place of hot glue, or is there something bad for the cap in the superglue? Thanks for any info.
-James-
-James-
