sine_wave
Active member
I started making a panel for my Trident Preamp build. The problem is, the switch is a 12-position type and I have no idea how to create an accurate, true to life graphic representation of it. I'm attaching a photo taken from the first Troodent built which clearly shows the graphic + switch.
If anyone has a graphic that will line up with this switch I would be super-grateful if you would share it.
Regards,
John
Regards,
John
