I have a psu from my T-Bone SCT700 (which is the GT-2B I believe) and I can safely say that the DU67 (poctop) PSU circuit with the 2 transformers and everything will not fit in there. Eric (tskguy) and I have found a suitable Hammond box available from Mouser that does the job nicely and Dan (collective cases) has a PSU box that is perfect as well (and it's machined and painted with a handle).chunger said:Winetree said:Will the Chinese 9 pattern P.S. (with or without Mods) work with poctop's U67 Kits?
I'll take:
2 SYT-5 (U67/87) Mics. With or without P.S. depending on above answer.
2 GT-2B W/O P.S. (For U47 Fet.)
I do not know if the oem Chinese psu will work with poctop's U67 kits. I suspect not as poctop's kit contains a PCB for the original PSU circuit that would probably have better filtering. I would venture to say the U67 PSU PCB is too large to fit in the oem case also. Dan from collective cases sells an excellent PSU case here on forum that is well suited for poctop's U67 kit.
The SYT-5 body kits are not complete microphones. They do not have psu's or any internal components except the capsule and capsule mount. I will put you on the list for
2 SYT-5 body kits
2 GT-2B microphones without PSU.
Please let me know if I have it wrong.
If someone was going to use the Chinese PSU box for a G7 circuit I believe that would work.
Just my 2 cents
Dave
