mindlessstudio
Member
- Joined
- Oct 4, 2012
- Messages
- 23
Hello there, returning customer after quite a few years here ... was busy, am back!
I've got a bunch of MD441s and one of them has started acting up. Basically, it only outputs very little, and there's almost no bottom end in it. Shaking it about a bit makes it go BOOM with loads of lows, but doesn't fix anything. I opened it up to see if its dia was easily cleaned, but it seems I have to take parts apart that I don't really know too well, so I thought I'd just hear if there's gurus in the house. A few more things: when I tap the inserts gently with a wooden toothpick (or indeed a great big hammer) it sounds exactly like you'd expect when you tap a mic, lots of lows etc. But when I speak into it, there's that almost no sound at all thing again. I've removed the (falling about) foam at the input end but since there's a grill at the end of the funnel behind it, there shouldn't be any nasty filth in the diaphragm part itself, afaik. So ... ehmn. What to do? Any suggestions are very very welcome
