micaddict
Re: Enchilada's Mic Builds - Current Project: U47 Inspired
« Reply #40 on: October 29, 2012, 08:26:36 AM »
I removed the two inner layers of mesh from the headbasket of my C12 clone tonight so hopefully that will open up the sound a little more.
There's no doubt in my mind it will.
Did you take pictures as you were going?
Enchilada
« Reply #41 on: October 29, 2012, 08:31:45 AM »
Bugger! I forgot to take photos of the headbasket removal. It's fairly straight forward though. I just used a flat tip screwdriver. The inner two layers of mesh are only soldered at two points.
I'll make sure I take photos along the way with my U47 inspired mic.
« Last Edit: October 29, 2012, 04:50:54 PM by Enchilada »
sedit1
« Reply #42 on: October 29, 2012, 11:26:31 AM »
I'm heading out to the studio with my friend Lauren on Thursday to record comparisons between this mic (with an RK47 and an EF800), both of my Royer modded MXL 2001 (one with an RK12 and one with an RK47) and my C12 clone with Tim's CT12 capsule.
Great news, I really want to hear diiferences between "U47" and your C12 clone, just starting the C12 clone myself. Also Interested hearing the M7 in the future!
dmp
« Reply #43 on: October 29, 2012, 11:34:37 AM »
Any tips on how you got them out? They look like they are soldered in on my apex 460 headbasket
Enchilada
« Reply #44 on: October 29, 2012, 04:49:58 PM »
Quote from: dmp
They are only soldered at two points. I used a small flat tip screwdriver and first pushed the mesh away from the lip that goes around the inside of the headbasket. Then I used wire cutters to cut around the solder joint. The result is quite clean. I was worried because I had heard of people using a Dremel to remove the mesh but it's really not necessary with this mic.
I didn't remove the mesh from the top of the headbasket because it looked to be soldered all the way around and I didn't think it would have much of an effect on the sound.
EDIT: I'll post photos of the headbasket today.
« Last Edit: October 29, 2012, 06:47:31 PM by Enchilada »
Enchilada
« Reply #45 on: October 29, 2012, 08:38:35 PM »
I've somehow managed to acquire the oldest looking EF14 tube on the planet! Despite its looks, it tested very good. I'm hoping the fact that it's glass won't negatively impact the sound of the tube. The socket hasn't arrived yet so I might have to solder wires directly because I'm that impatient.
Looks like my test with Lauren on Thursday will be with my Beesneez M7 capsule, EF14 tube and AMI T47 transformer  ;D
« Last Edit: October 29, 2012, 08:45:15 PM by Enchilada »
Enchilada
« Reply #46 on: October 30, 2012, 09:13:31 AM »
Started putting it together, just waiting for a few resistors before I wire it all together properly :). As is my usual style, not the cleanest build but it will work.
Dylan W
« Reply #47 on: October 30, 2012, 12:28:00 PM »
Looks great, nice snag on the EF14. Expecting a shootout!   ;)
Dylan
Volume11
« Reply #48 on: October 30, 2012, 03:15:55 PM »
How did you go about testing the tube? Tube tester, another mic...?
Enchilada
« Reply #49 on: October 30, 2012, 05:04:34 PM »
Tube tester
« Last Edit: October 30, 2012, 08:48:20 PM by Enchilada »
Enchilada
« Reply #50 on: October 30, 2012, 08:52:22 PM »
Dylan
Thanks mate, I'm heaps keen to hear the shootout. Even though they're in different circuits it''ll be good to hear expensive capsules vs cheaper options. My console is out of order for now (rebuilding the power supply) so I'll record them through my SPL preamps.
I might even do it as a blind shootout and make it into a game of "guess the mic", I've always wanted to host a blind shootout. :P
Gus
« Reply #51 on: October 31, 2012, 04:25:10 PM »
with all the information on the web why did you mount the tube so far away from the capsule?
Enchilada
« Reply #52 on: October 31, 2012, 05:10:13 PM »
Does it really make that big a difference with noise? I put the tube down the bottom because the rails are closer together. It made it easier to mount the both the PCB and the tube.
The C12 had plenty of distance between the capsule and the grid. I'll be using some teflon wire which will help.
« Last Edit: October 31, 2012, 05:18:41 PM by Enchilada »
Enchilada
« Reply #53 on: October 31, 2012, 07:26:32 PM »
Beesneez capsule arrived  ;D ;D ;D
I love the way it is packaged! Brass tube with nylon (I think) ends. The capsule is mounted on the bottom nylon plug and it looks amazing! I'll take photos of the capsule with my DSLR when I get home.
Enchilada
« Reply #54 on: October 31, 2012, 11:41:07 PM »
Resistors all arrived today too. Soldered them all in and also replaced the output cap with a big fat polypropylene one. Haven't fired it up yet, I'll do that tonight.
Volume11
« Reply #55 on: October 31, 2012, 11:58:35 PM »
Aaaaaaahhh I'm so jealous! I can't wait to get mine, I'll be looking forward to those pics. That packaging is definitely unique looking.
HellfireStudios
« Reply #56 on: November 01, 2012, 01:13:04 AM »
Yes.
-James-
"Tommorrow is just yesterday in reverse. Just like friends are enemies in reverse." -Gary Busey
Enchilada
« Reply #57 on: November 01, 2012, 05:30:53 AM »
Here's a little shootout. Unfortunately, the U47 clone is not yet ready so it will not be competing this time around :-(.
Let's proceed. We have one C12 circuit with a CT12 capsule and two Royer circuits with RK12 and RK47 capsules. I have listed the mics in alphabetical order so as not to give anything away although I think it's fairly easy to tell which mic is which.
http://soundcloud.com/fat-wombat/sets/lauren-carlson-teenage-dream
This will be a semi-blind test because I've attached which mic was which in a text file if you want to know. Have a guess first though  ;).
micaddict
Re: Enchilada's Mic Builds - Listen to the shootout!
« Reply #58 on: November 01, 2012, 06:34:45 AM »
 :D
The 47 (not telling here which number) was easy. The 12s were maybe a little trickier since the circuits aren't the same.
Enchilada
« Reply #59 on: November 01, 2012, 06:53:05 AM »
:D
So what's your guess/preference?
Last post June 26, 2020, 06:34:46 PM
by Catrunes
Last post September 19, 2012, 09:14:27 AM
by leitrim_lad
Last post April 27, 2015, 12:38:10 PM
by Biasrocks
Last post May 31, 2013, 11:12:05 AM
by Melodeath00
