micaddict
Re: Enchilada's Mic Builds - Current Project: U47 Inspired
« Reply #20 on: October 19, 2012, 10:41:57 AM »
Was it a 60 mm pipe, now "shaved" to 58.5 or so?
Enchilada
« Reply #21 on: October 19, 2012, 10:45:30 AM »
60mm shaved to 57.5mm. That's the dimensions of the GT-2B.
letterbeacon
« Reply #22 on: October 19, 2012, 12:57:44 PM »
That looks great!  What do you mean by 'shaved'?  Would you be able to tell us what was involved in making the body?
Enchilada
« Reply #23 on: October 19, 2012, 06:06:48 PM »
When I say shaved, I'm just using micaddict's vernacular. I got a piece of galvanised 60mm tube for free from a steel place and had it machined by an engineer. He took 2.5mm off the outside and copied the ends of the original body so it would be a perfect fit. It cost me $30 so I think it was worth it.
« Last Edit: October 19, 2012, 06:10:50 PM by Enchilada »
micaddict
« Reply #24 on: October 20, 2012, 05:01:41 AM »
Going by the picture, I would agree.  :)
« Last Edit: October 20, 2012, 09:18:56 AM by micaddict »
letterbeacon
« Reply #25 on: October 20, 2012, 05:55:25 AM »
Ah I see, so you thinned out the wall thickness of the steel?  Must have had pretty thick walls to begin with!
Gus
« Reply #26 on: October 20, 2012, 08:05:12 AM »
It was galvanised pipe but when it was machined they took off the gal. Not stainless though. I thought about nickel but there's nobody locally who can do it and I don't want to have to send it away.
You might want to search for something like  "galvanized steel msds"
IMO it is a good thing to search for the MSDS before machining, drilling, cutting etc materials.
micaddict
« Reply #27 on: October 20, 2012, 09:12:31 AM »
If using corrosive steel, do you need to treat the inside, too? Not for looks obviously, but to prevent any possible future problems (like rust dust on the electronics)?
« Last Edit: October 20, 2012, 11:12:12 AM by micaddict »
Enchilada
« Reply #28 on: October 20, 2012, 09:52:16 AM »
There's nothing hazardous about gal pipe. As I said earlier though, I didn't do the work. I had an engineer do it. Also, I won't have to treat the inside because it's still galvanised.
« Last Edit: October 20, 2012, 09:58:22 AM by Enchilada »
micaddict
« Reply #29 on: October 20, 2012, 11:14:02 AM »
Makes sense. I asked because I may have some iron pipes coming my way.
Anyway, on with the build.  :P
Gus
« Reply #30 on: October 20, 2012, 01:08:01 PM »
Are you sure?  have you looked up machining it and the dust/metal particles?
IIRC There was a post in a thread with someone using a chop saw to cut G10  read the MSDS
Read about what gasses and fumes are released machining some plastics if they get over heated
Teflon has issues
http://modelsteam.myfreeforum.org/archive/burning-teflon__o_t__t_38325.html
People with the web and search engines finding MSDS's and also typing in how to machine and/or safely issues is something IMO one should do before cutting a material.
Enchilada
« Last Edit: October 21, 2012, 06:48:32 PM by Enchilada »
Enchilada
« Reply #32 on: October 21, 2012, 05:11:42 PM »
New paint  :D.
It looks much whiter in this pic than in real life. It's more of a light beige in person (photo below).
« Last Edit: October 22, 2012, 04:24:51 AM by Enchilada »
Dylan W
« Reply #33 on: October 21, 2012, 05:46:25 PM »
Nice!
Dylan
Enchilada
« Reply #34 on: October 22, 2012, 04:22:51 AM »
Shock mount arrived today  8)
manulaudic
« Reply #35 on: October 23, 2012, 04:11:53 AM »
This looks wonderful :)
Enchilada
« Reply #36 on: October 28, 2012, 07:43:44 PM »
Received four EF800 tubes and my AMI T47 from Oliver in the mail today, let the fun begin! Oliver was even nice enough to throw in an EF80 tube for me to try out, what a champ.
My Bees Neez M7 is also in the post but should only take a couple of days seeing as I'm in Australia. I'll build the circuit tonight with the EF800 and an RK47 capsule for comparison purposes and then I'll get some samples up when the M7 arrives. With some luck my EF14 and EF12 might also turn up this week and I can compare all the tubes.
« Last Edit: October 28, 2012, 10:04:18 PM by Enchilada »
Enchilada
« Reply #37 on: October 29, 2012, 12:50:30 AM »
This transformer looks and feels of fantastic build quality. The best thing about it so far for me is that I assumed I would have to cut a hole in my PCB to mount it but I won't because the pins are below the windings  8).
micaddict
« Reply #38 on: October 29, 2012, 06:47:41 AM »
Yep, both the T47 and T67 (as opposed to the BV8 and BV12 respectively) are "PCB mounted" versions.
A lot less expensive, too.
Enchilada
« Reply #39 on: October 29, 2012, 07:28:58 AM »
I knew it was PCB mounted but other PCB mount transformers I've seen that are PCB mount need a hole cut and I assumed wrongly that this was the same design.
I'm heading out to the studio with my friend Lauren on Thursday to record comparisons between this mic (with an RK47 and an EF800), both of my Royer modded MXL 2001 (one with an RK12 and one with an RK47) and my C12 clone with Tim's CT12 capsule.
I removed the two inner layers of mesh from the headbasket of my C12 clone tonight so hopefully that will open up the sound a little more.
Last post June 26, 2020, 06:34:46 PM
by Catrunes
Last post September 19, 2012, 09:14:27 AM
by leitrim_lad
Last post April 27, 2015, 12:38:10 PM
by Biasrocks
Last post May 31, 2013, 11:12:05 AM
by Melodeath00
