figuringstuffout
- Joined
- Dec 10, 2011
- Messages
- 45
So, it's been a while since I have posted about one of my assorted problems with tube amps...but here is another one driving me nuts.
PROBLEM
On several amps I have built recently (3) I am having a problem where the signal is somehow bleeding through even with the master volume all the way down. The signal is without any low end, and when I turn the volume up the full signal increases until it is louder than the signal that bleeds through. When the volume is up everything sounds great.
CONSISTENT PROBLEM
The amps this is the biggest problem for are my high gain amps (4-5 gain stages - very similar to the SLO), and the signal does completely go away when the gain is turned all the way down. If the gain is up but the master down, then the problem is there and loud enough to be very annoying.
However, even on amps I am building that have low gain (two 12ax7 gain stages with a High Low tonestack before a phase splitter) and no master volume, the problem persists even when the gain is all the way down (granted the problem is way less noticeable)
OBVIOUS CONCLUSIONS/IMPORTANT POINTS
1. This is a consistent issue for me and thus is something I am doing wrong
2. The more gain, the louder and bigger problem it becomes
3. Probably not the pot causing the problem since it has happened on several amps now
4. Problem persists whether there is a bypass cap on the gain pot or not
5. Grounding issues are an obvious choice, but I am using a star grounding scheme (maybe poorly). I ground the input to the first cathode resistor. Each stage is grounded to its cathode resistor (ground side) (including the pots) which is then grounded directly to it's filter cap. Filter caps are grounded to the chassis together on a lug bolted to the chassis. Other lugs are grounded to this bolt as well coming from the first filter cap/OT/and speaker out, and another one has the center taps from the PT.
6. If I ground certain grids then the problem stops, but with others the problem persists, especially in the high gain designs. If I physically ground the signal before or after the master, the problem is unchanged. In the high gain amps, if I ground right before the PI, or the grid before the final gain stage, the problem goes away in that the signal finally stops. So the bleed seems to be happening right before the last gain stage and possibly at the PI as well?
QUESTIONS
1. Could this just be a grounding problem?
2. Crosstalk from a bad layout? I base my layouts on what I see in classic amp layouts (IE - Triodestore or Ceriatone layouts)
3. Some of my RC dropping resistors are as low as 1K5, some as high as 10K (usually 10K is for the first stage)...could this be an issue?
4. Is it possible to be bad pots on every amp?
5. Any other ideas?
Thank you for your time dealing with this noob...=)
PROBLEM
CONSISTENT PROBLEM
QUESTIONS
5. Any other ideas?
