U87i problem
Biasrocks
Windsor, On, Canada
Older U87i (not A), brand new Thiersh reskin capsule, Cardiod and Omni sound and react as they should. Figure 8 pattern goes almost dead.
Any ideas where I should be looking?
Pattern switch maybe?
Regards,
Mark
have you confirmed that the two backplates are isolated from each other?
Are you using a new switch assembly on an old mic?
Are there four wires going to the capsule?
Yes, I verified that there was no continuity between the backplate halfs.
No, the original switch is there.
Yes, two to the middle of the capsule.
One to a tab on the backplate and the forth connected to the plastic tab holder going through to the backplate.
It seems that one of the backplates wasn't making a connection to the wire tab. There was a small piece of plastic under the tab which I removed and now it's making a connection. My figure 8 is still significantly lower in level.
Here's an MP3 of how it's sounding.
http://Sharktankpro.com/Media/U87-Test.mp3
Cardiod, Omni, Figure 8
Regards,
Mark
