Hello Folks,
This is the Eden Microphone Preamplifier from Expat Audio.It comes are a completed module that only needs to be hooked up.
In fact, all it needs is power, input, output and a gain setting resistor.
It's assembled and tested here in Texas, USA.
Similar SystemsIC Mic Pre's like this have been used many systems, such the Toft ATB Console, Trident S-20 mic pre, the DAV BG1mic pre, Symetrix 302, dbx760X, D+R and Amek consoles. (that list from searching online)
PerformanceIt has flat THD+N at 30dB of gain as low as 0.003%, all the way to 30kHz (higher I believe - but the audio test kit isn't quite up to it).
At 60dB of gain (max setting) the THD+N is still very impressive at 0.04%. (again, flat all the way!)
When will it be available?Now Available at Expataudio.com
How much will it cost?Fully assembled and tested. (all the parts you need).
1x set $79.99
4x set $239.99 (equivalent of $59.99)
Where can I buy it?Please head on over to:
http://expataudio.myshopify.com/products/eden-microphone-preamplifierWhat about the parts?A full bill of materials for a 4ch 1U Eden system can be found at:
http://groupdiy.com/index.php?topic=54445.0However, the Eden board itself comes fully assembled. You only need to add a front end (switches for phantom, phase etc) and a gain control resistor.
Is there a case available for it? I hate making my own cases!"Yes - Head on over to
http://www.collectivecases.com
Rochey
