AMI T13 batch Errata U87 Build !!!!!!!!!!!!!!!!!!Low output problem (Solved)
poctop
White Market Member
IMPORTANT NEWS,
I actually have one unused T13 here and it reads 22R Yellow and 420R black ,
So the information on AMI website is in the need to be confrimed because my transformer color code here would not work as connected like the AMI website reference ,  WOW  :eek:  this might be the cause for all of you that had problem with lower output microphone,  would seems that some of the transformer are actually the wrong side outhere,
I have to say that i feel so much relieved of this findings,
I might have to say to all of those that had this problem to check it out because this will solve the issue garanteed,
and you will be able to finally enjoy the mic as intended at the first place,
i will notify Oliver as well , please post on this thread if you have an inverted color coded transformer ,
to see more  page 67 -68 here
http://www.groupdiy.com/index.php?topic=48030.1320
Picture attached of the compromised color coding ,
Dan,
8)
