michael allen
New member
- Joined
- Dec 1, 2012
- Messages
- 2
I want to rig up a panic switch for use on stage so the singer can mute the FOG and still talk to the in ear monitors the band wears. I drew this up inspired by RG's article on geofex and thought I would post here for comments/suggestions. I've learned a lot from reading this board and hope this is helpful to someone.
Essentially uses optocouplers to isolate/mute the PA input from the mic source which is hardwired to the monitor input. Actually the way I'll use it is two separate channels on the same board, with one muted in the house. I gather that the limit suggested for passive splitting without a transformer is 3x so two outputs should be fine.
It may turn out that I want to boost the singer volume in the monitor when muted in the house so I may insert a second set of switches for the monitor out that operate inversely to the switches for the front of house, so that I have a real A/B instead of A + B. This way I can set the level of the singer from output A in the monitor mix, and mix in more of B so that when the panic is hit the singer will be clearly heard over the rest of the mix.
Any problems I'm not seeing? I think this should be click free but any extra insurances?
