DB-25 Summing Boards... with some cool features.
Israel
Well, here is... Universal summing PCB.
First 2 channels can be panned (LCR) and panning law (-2, -3, -6 or 0 db) can be set with resistors.
As well, first 2 channels can go out for monitoring purpose and/or muted.
Cool!
Your announcement is just right... got some Lawo sum-cards lying around searching a new home.
I was designing something similar, but without the nice add ons. An error happend during PCB maunfacturing. That is where I stopped.
Tell us more - I can see that the pinout is according to the Tascam Standard and the boards are linkable...
When will those boards be available? Will need at least 4.
Regards,
Christian
Hi Igor,
a few questions about this summing card :
1 - why you decided to make pannable only the first two channels and not all the eight ?
2 - what you mean the first two channel can go out for monitoring purpose and/or muted ?
3 - when the card are ready , and you sell it by kit or only card ?
4 - if i have a neumann card can i connected to this card ?
Let me know
Thank you Man !!
Fabio
Audioman said:
Hi Igor,
Let me know
Thank you Man !!
Fabio
1 - because I usually don't need panning on rest 6; but I have a plans to do a bit different thing with all 8 channels pan/mute;
2 - mean, you can use first 2 channels for monitoring and not send them to mix;
3 - cards will be offered in White PCB Series very soon;
4 - if you mean zero field input transformer with zero input impedance oldies, yes, of course;
5.... and many transformer input pre's as well :)
