G1176: Turn Switch to Push Button Wiring : Diagram Enclosed
« on: January 22, 2005, 06:34:45 PM »
Hello all:
I am trying to wire my G1176 with some push button switches instead of the called for lorlin.  I don't have the ability to make a PCB that I saw was made for push buttons so I tried to wire it directly from the PCB the switch was on.
Does this look right to you guys?
Michael
P.S.  I think it is correct but to my ears it seems that my 4:1 compresses more than my 20:1...do i have it backwards?
mnats
« Reply #1 on: January 23, 2005, 12:47:46 AM »
Michael,
It appears that 7, 8, 9 and 10 are inverted in your example. So using the current labeling, connect 7 to 10, 8 to 9, 9 to 8 and 10 to 7.
« Reply #2 on: January 23, 2005, 07:02:08 PM »
You totally right!  That was a typo.  I actually had them wired the right way.  I appreciate you catching that.  I was not sure I had it right though so the help was surely needed.  I updated the pic for anyone else interested.
Now...how do i do the Meter Switch.  here is what I have so far.  The "?a" is what I dont really know.  How does the rest look?
Michael
mnats
« Reply #3 on: January 24, 2005, 02:00:33 AM »
1, 2, B, C are correct.
3 on the pushbutton should go to 6 on the rotary board - R51 to pad Y.
12 on the pushbutton should go to 9 which is connected to pad X. These latter two are for the +4 setting so they need to connect to the output on the line amp.
4 goes to 4 = ground. Correct, but the designations are confusing since there is also a pad 4 on Jakob's layout.
A goes to A = pad 22 which is also point 22 on the schematic. So that is also correct.
?a therefore should go to rotary pads 2 or 3, which goes to pad 4, connecting to the ratio switch common or GRN on the original schematic. But since pad 4 on the meter board just goes to pad 4 on the ratio board, just wire it directly to the ratio board pad 4. It should probably be shielded with the shield grounded on one end.
Last post June 08, 2007, 03:41:13 PM
by rotation
Last post September 25, 2007, 09:41:51 AM
by sodderboy
Last post May 29, 2009, 08:20:41 AM
by barclaycon
Last post October 01, 2019, 02:00:33 PM
by weiss
