dirtyhanfri
Hi
I'm building a SSL9k PSU from the neeno's pdf for a Studer 169 Eq, using a 15V transformer and 78-7915 for the regulators. I'm not populating the +48V part of the pcb so it's quite simple. But in the first run one of the electrolytics was wrong oriented with his consequent explosion and bad smell. It was the one before the 7915. I replaced it with the correct orientation and now the positive rail is giving me +20.1V (I think it's a bit high, but maybe it's just because it has no load, anyway, it won't blow the 5534's in the EQ) but the negative rail is giving me 0.1V.
No one of the other caps looks wrong, the board is properly grounded (or I think so...) the earth mains is going to chassis, no shorts or something in the board, the fuse don't blow, well, the reg hasn't the best dissipation (I have no heatsinks at hand so I used aluminum paper to make some kind of heatsinks ;D)
Could the 7915 be damaged by the bad position of the cap?
That makes me think how many times I replaced 78-79xx in my builds... Should I take a look into lm317 power supplies and start avoiding 78-79xx? Is the lm317 really better or I'm just having bad luck?
