Low End Preamp to Medium End :D
I think a 'millivolts generator' would be closer to reality...
(Anyway: under normal circumstances a 4.7 or 5.6 V zener won't conduct because of the microphone output.)
You would be surprised. I would not like to take the signal level coming from a kick drum lightly.
See the maximum output at below link;
http://www.microtechgefell.com/index.php/en/microphones/studio-a-recording/small-membrane-transistor-mics/429-m-221
THAT corp wrote a pretty good AES paper about input protection. Yes you want to prevent the input devices from zenering (<<7V), but transients from shorted, charged up, phantom supply blocking caps can drive the inputs negative a few tens of volts. Oversized input caps means lots of current must be clamped, too.
I believe you mean "More Analog Secrets Your Mother Never Told You"? http://www.thatcorp.com/datashts/More_Analog_Secrets.pdf
My recollection was a separate paper just about input protection, but that paper gives it a good treatment, and looks like it has some other useful information worth reading.
Back in the day I learned a lot from the national audio applications manuals. While they always pimp their own products you can still learn a lot of the basics from such sources.
I suspect THAT engineers were forced to rapidly develop expertise about input protection from trying to keep their chips alive inside customer applications. On-chip clamps can rarely handle a full dump from an oversized input cap... bigger must be better right?  :eek:
rıdvan said:
Why no one talks about my schma? :eek:
No one talks about your schema because you need to work on it some more. The power supply will not produce + and - voltages as you have it drawn. Try running a full wave bridge (4 diodes) from each of the 12 volt windings, to make two separate 18 volt supplies if that's what you want. The phantom supply is somewhat complicated, a full wave bridge and a 48 volt zener is enough for the regulator, at this point.
