Yep, that is the config..no answer from them on the schematic and a web/news search turns up nothing as well..I just got (10 minutes ago) my telefunken 12ax7's to put in..I noticed a large improvement immediately...a little clearer and more present..I am letting them warm up before i do a little singin'..I have a nice digital camera so I can send you as many pics as you want..Thanks so much for the helpl on this..tonight I am going to bypass the caps in the output section rendered useless by the burr brown 2604 op amps..Tommorow I am going to order the replacement caps from digi key and 2 lundahl mic input transformers..as for the power supply here is what I read...
I changed R1 and R28 from 10K to 2K5. This is in series with thetransformer secondary and the grid of the first stage, and thismodification reduces any possible noise from the 10K resistor andmoves the HF rolloff up 2 octaves. I also replaced the shuntcapacitor (C1, C12 = 27pF ceramic) with a 26pF polystyrene to make itsound nicer.Other resistor changes: I removed R59, R60 (47K), R2 and R29 (10K) forsome reason, probably because they added some pad function to thetransformer secondary that wasn't the right way to go. Sorry to befoggy on the details... but the mike line pad is still available andseparate from this pad.I bascially replaced all caps in the signal path (which are ceramicand mylar as stock) with polystyrene or polypropylene caps. One coulduse paper and oil caps if you want a more smeary 'vinatge' sound, butI didn't. The cathode bypass caps went from 47uF Al electrolytics to100uF solid Ta electrolytics. I hate recapping, and Kemet solid Tacaps should last a lot longer. As I recall, I replaced all Alelectrolytics in the signal path with Kemet solid Ta electrolytics,usualy of a slightly larger size. The output electrolytic couplingcaps were removed and replaced with jumpers.One important cap to remove is C6 and C16 (120pF ceramic). This capshunts the second stage plate and serves as an HF rolloff to make thecircuit stable. It is not needed with a lower ratio input transformerthat has no huge ultrasonic peak, and it only adds HF distortion.Clip it out, but only if you change transformers.The output stage uses a pair of dual op amps (BA4560 as stock), andthese should be replaced with something better. I have OPA2604 inthere now, but I might try the LT1469 because they have a cleaner HF.Not that this is a clean amplifier, mind you, but just to see if itsounds any nicer.The power supply can also be improved. The heaters run off ofregulated DC, so there's no issue there, but the HV supply can beimproved. As stock, it's a simple RC filter following the rectifier,and if you change this to a two stage filter by adding another filtercap and a resistor, you can get less noise and higher plate voltage.Reducing the value of the series resistor increases the resultingplate voltage, but worsens the filtering. Having two stages offiltering redcues the hum, but you end up with less voltage drop and ahigher resulting supply voltage, and that generally reduces thedistortion of the tube stage.Finally, the stock cheapo 12AX7 can be replaced with something better.I had a nice pair of Telefunken 12AX7, so in they went.When I have the time, I want to replace the output pot, as it seems tobe a linear taper pot or a really poor log taper pot. I want to geteven less gain from the tubes, so a change in the gain structure wouldprobably be in order. I might even change it to a single tube stagejust to avoid having to do so much feedback. A different tube typemight also be the answer there - something like a 12AT7 and new plate/ cathode resistors might be the ticket....
I will work on it tonight and post again tommorow
Ray
[/i]
