mik said:Generally speaking ; the 10K:10K type are for input, and 600:600 for output.
best
M.
ruffrecords said:Maybe we should have a transformers meta?
ian
G-Sun said:Yes, a transformer meta would be nice. Both for the theoretical and more practical sides of transformers.
gemini86 said:Just go through CJ's post history, you should be able to find just about everything you ever needed to know about transformers.
In one word, no. You need to measure it with AC, and the result is an impedance. A transformer winding being an inductance, the impedance varies with frequency. There may be a point where you 600ohm winding may measure 600ohms, or your 10k winding will measure 10k, but this is to be taken in relationship with frequency.G-Sun said:Thanks folks!
I thought secondary ohm was dependent on primary ohm, in a square relationship. Isn't that right?
Or can I measure 600ohm just unconnected for a 600:600 primary/secondary?
Thanks a lot! I'm starting to grasp it a little. But, frequency: don't we in pro-audio always need to design for at least 20Hz? And would that change from a mic-out to a preamp-in?abbey road d enfer said:You see that the targetted application is significant there; transformers spec'd for 20Hz LF cut-off need a higher inductance than those designed for 50 Hz.
I agree an "inductive components" meta is more and more needed.
vineyardgray said:What about this transformer meta already created by the aforementioned CJ?
http://www.groupdiy.com/index.php?topic=467.0
That's what good practice suggests, but there are some exceptions. For example 70/100V xfmrs for distributed sound systems are generally spec'd for 40-50 Hz. And some vintage units may have used a different set of rules.G-Sun said:But, frequency: don't we in pro-audio always need to design for at least 20Hz?
CJ said:from Grossner, Transformers for Electronic Circuits pg. 179:
"because the circuit behavior is least complicated at wm, it is customary to specify several important transformer characteristics at the mid-band frequency:
(1) the rated power
(2) either the turns ratio or the desired impedance seen at the input when the secondary is loaded; and
(3) the desired minimum efficiency, or the maximum insertion loss (also called flat loss)."
and a good point is made above on the transformer Z dropping to zero, at which time you have a current source feeding the transformer instead of a voltage source,
current transformers operate down near zero input Z, the pri is just one wire,
that meta is pretty stale, just a bunch of vendor links,
ok, i moved the article section in the Transformer Meta to the top of the page,
not enuff space to add these bookmarks to the meta, error message: "warning! yo have gone over 20,000,000 words
start with these two:
here is a start from the Jensen site:
http://jensen-transformers.com/an/Audio%20Transformers%20Chapter.pdf
very historical, starts out: "Fred Flintstone discovered a compass in 1498 BC,..."
http://www.sowter.co.uk/pdf/GAVS.pdf
so here>
http://www.alcatel-lucent.com/bstj/vol07-1928/articles/bstj7-4-762.pdf
http://www.rsp-italy.it/Electronics/Magazines/General%20Radio%20Experimenter/General%20Radio%20Experimenter%201942%2003.pdf
http://powerelectronics.com/mag/power_inductors_equivalent_circuit/
http://www.vias.org/eltransformers/lee_electronic_transformers_06_10.html
http://www.classicaudio.ru/articles/ot_distortion_p2_a57.pdf
http://www.junkbox.com/electronics/utc_transformer_catalog_1963.pdf
http://www.jensen-transformers.com/an/Audio%20Transformers%20Chapter.pdf
http://www.coilwinder.com/Magnet%20wire%20data.htm
http://books.google.com/books?id=wyiFxKP2OnQC&pg=PA169&lpg=PA169&dq=supermendur&source=bl&ots=653QJBp_Rc&sig=ktT4pc_UfrL47GPdWsSvO0penTQ&hl=en&sa=X&ei=UK_KUIGLAc6ajAKOloC4DQ&ved=0CEcQ6AEwBDgK#v=onepage&q=supermendur&f=false
http://www.infernalemachine.fr/TECH/NEUMANN/U47Tranny_Winding.pdf
http://www.vias.org/matsch_capmag/matsch_caps_magnetics_chap3_18.html
http://www.micrometals.com/material/pc_coreloss_txt.html
http://www.professionalplastics.com/NOMEXPAPER
http://www.tubetvr.com/transformers.pdf
http://richard984.tripod.com/transformer_math.htm
http://info.ee.surrey.ac.uk/Workshop/advice/coils/gap/index.html
http://info.ee.surrey.ac.uk/Workshop/advice/coils/mu/
http://books.google.com/books?id=axyWXjsdorMC&pg=PA354&dq=mu+metal&hl=en#v=onepage&q=mu%20metal&f=false
http://www.aircraftmaterialsuk.com/data/electronic/almu.html
http://cartech.ides.com/datasheet.aspx?i=103&e=206&c=TechArt
http://books.google.com/books?id=ufGdyu24X2EC&pg=PA388&lpg=PA388&dq=4-79+permalloy+relative+perm&source=bl&ots=_YaxrcL_EL&sig=641hSSUJP0jsusY30qpcf6AmEGc&hl=en&sa=X&ei=8BKvUMqHDae9iwLnu4HwDA&ved=0CD8Q6AEwAw#v=onepage&q=4-79%20permalloy%20relative%20perm&f=false
http://www.magmet.com/lamination/pdf/Superperm49.pdf
http://www.coilgun.info/theorymath/home.htm
http://www.ebay.com/itm/Magnet-Wire-26-AWG-Gauge-Enameled-Copper-155C-5lb-6290ft-Magnetic-Coil-Green-/251135985868?pt=LH_DefaultDomain_0&hash=item3a78df08cc
http://diyaudioprojects.com/Technical/American-Wire-Gauge/
http://www.laminationspecialties.com/
http://www.tempel.com/products.asp?cat=11
http://en.wikibooks.org/wiki/Electronics/Transformer_Design
http://ia700401.us.archive.org/31/items/ElectronicTransformersAndCircuits/Lee1955ElectronicTransformersAndCircuits.pdf
