Sorry, Bruce, I've been busy tonight.
Looks like I'll need to update the BOM,
C5 and C2, Those should be 100V parts at least, best to go 250V. The original G9 BOM says 250, but it also specifies 250V for C10, which doesn't have any dc on it. In the 51X world, real estate is expensive, but I left footprints for 5mm,7.5mm, and 10mm (I accidentally grouped C2 and C10 together on the BOM.)
The input stage is a cathodyne type, where the tube has a 47k resistor on plate and cathode, then a biasing resistor to bring the grid down below the cathode. The grid is actually up at around 80V relative to ground, or, your guitar. In a normal gain stage, with a grounded grid, there would be no need for a cap at all, as you see in your LCMP circuit.
Also need to sort out some HV converter details in the BOM- I did the math for the feedback resistors to give an output of 240V. When I did stuff those resistors, I ended up with something more like 265V, which is too high. I had to dial back the resistors some to compensate. (I'll have to look to see what's I ended up with there, I'm unable to get to my work bench right now.) The original had a trim pot which was nixed due to possible instability problems.
