Racking an ADM Stereo EQ
abarcane
New member
I just bought an ADM Stereo EQ. I have never racked anything before. There are no schematics. This is the info I have on the module so far.
I'm guessing the model is ADM 1530. It has 3 bands of sweepable EQ, with peak/shelf switches on the high and low bands. Switchable high and low cut filters and a bypass switch. The module has dbx 2151 VCA chips, 12 in total. Small enough to fit in a single rack space case with a power supply. +/- 15 volt regulators on board for each channel. You would have to feed it +/- 18 to 20 volts or else remove the regulators and feed it +/- 15 volts from a regulated supply.
I can't imagine this being very hard. But I don't have any schematics to go from. Can anyone help me ?
this might help.... don't know if it works... never did manage to rack mine.
