Hello people much smarter than I am:
I built an LA2a clone a few years back (essentially following the Cayocosta wiring with some mounting alterations). It's been a wonderful unit functioning pretty much as expected until the other day...
The compression side-chain stopped working. The unit continued to pass audio.
I should have stopped after I got to the following voltages:
AC: 122
C7b(+) 280
V1 1: 123
3: 1.1
6: 127
8: 1.1
V2 1: 102
3: 4.3
6: 230
7: 78
8: 108
V3 1: 273
3: .1
6: 274
8: .9
V4 2: 5.5
5: 174
6: 97
I tested the resistors and capacitors around the exceptionally high voltages (in red) and they were within tolerance. I was not able to find any shorts or ground faults.
I decided to swap the 12AX7 tubes (in retrospect, stupid). The sidechain appeared to work, the output circuit appeared to fail. OK. Bad tube.
I replaced the 12AX7 in the side chain today (and placed the confirmed-ok tube back in the audio circuit). Annnnnd... now both circuits are failing. The voltages remain out of whack.
The only odd symptom that I've had in the past is that the meter bulb burns out quickly - I've just stopped replacing it. Other than that this unit has been fairly quiet (around -55 db noise floor on the low end - clean up top).
I'm at a loss for what to test. I'm hoping someone else has seen these voltages or can tell me where in the circuit I should look for faulty parts or wiring.
Thanks for taking the time to read this. Your genius is much appreciated.
--Leo
AC: 122
C7b(+) 280
V1 1: 123
3: 1.1
6: 127
8: 1.1
V2 1: 102
3: 4.3
6: 230
7: 78
8: 108
V3 1: 273
3: .1
6: 274
8: .9
V4 2: 5.5
5: 174
6: 97
--Leo
