Timothytitus88 said:
What about Altronics. They are in OZ, and pretty good quality....
http://www.altronics.com.au/index.asp?area=item&id=H5032
They are actually not very good quality.
There are a number of issues with these cases.
1.) Rear panel is painted, so you generally make a complete mess of it when drilling holes as the paint begins to peel off and can, if you are unlucky, come off in chunks. Not good, it should be anodized like the rest of it.
2.) There are a number of small misalignments with the case. For instance the top panel has never been truly flush on a single one of these I've bought (I've bought 2x 1U and 2x 2U, but never again....).
3.) The screws that are included + the threaded mounts for them last for about 2-3 screw/unscrew cycles until the unit begins to strip thread and basically fall apart.
4.) The front panel contains a groove top and bottom (it's more like a perpendicular strip top and bottom that you screw into, instead of the usual front mounting screws) which makes DIY CNCing one immense PITA as these channels continuously get in the way. I've even snapped CNC drill bits accidentally hitting them. Very annoying.
I really dislike these cases and would never recommend them again.
So anyone with a suggestion of a case that nicely addresses all of my points would be very very welcome also.
I've already looked at many options, and will take the previous advice also.
Jaycar cases in Australia are not much better. They SEEM better initially, but the go together like a weak mechano set, and unfortunately the misalignment issues are present, with the added issue of paper thin rear panels that don't drill very well at all.
For comparison the SB4000 1U rack case that I got that's part of the original specified kit is by and far the best quality case I have worked with thus far. Everything is perfectly flush, very strong, and I've taken it apart multiple times with no wear and tear at all. I need more cases like that one. It also feels really solid and is heavy. The Altronics ones feel like cardboard in comparison.
