Help about Grundig CN 730 Hi-fi (Playback EQ & DOBLY)
rıdvan
I bought an Grundig CN 730 Cassette Recorder-Player for 2$.Yeah that's right! Only 2$. ;D
But i have an problem.I can listen stereo but i can't record stereo!
It has 8 pin din socket like this;
But i can't find 8 pin socket.I have 5 pin but when i record,i just record mono.I need info about this type input to build my own connector.
DIN-connectors for microphone inputs are nearly always mono, 5-pin (or 3-pin).
For line inputs/outputs they can be stereo in one 5-pin.
If you have only one DIN connector, chances are that the recorder only has one micpre.
Jakob E.
Jakob E.
But every DIN connector's pinouts are different.I found lots of  info about 5 and 8 pin DINs but they are different :-\
I just did a quick search on the web and found the same document you posted. The next page includes "dynamische stereomikrofone und kondensator-stereomikrofone..." I would try to locate a schematic...
Actually there is no need.Cause i opened it and chopped :D
I get lots of old component from it.
Thanks for help!
