zebra50
Recovering corrupt wav files? Pro tools
« on: January 28, 2013, 06:02:12 PM »
For some reason i have one bad wav file in a recent pro tools session. I can see the file in the macos finder, but it won't play in protocols, iTunes, or QuickTime. The size of the file looks correct so I wondered if it is a corrupt header?
Does anyone have any tricks for recovering the audio from such a file? It is one of the kick drum mics and it would be nice to have it back!
Thanks loads
Stewart
« Last Edit: January 28, 2013, 06:35:15 PM by zebra50 »
Ribbon microphone services
http://www.xaudia.com
Microphone blog
Kingston
Re: Recovering corrup wav files? Pro tools
« Reply #1 on: January 28, 2013, 06:16:15 PM »
No idea how to do it on OSX, but if all else fails, take it to someone who has any version of (windows) wavelab, sound forge or even the free wavosaur audio editor and open the file as "raw" format. You then have to manually select bitdepth and sample rate and if the file is interleaved stereo or mono, but all the audio data is most likely intact.
zebra50
« Reply #2 on: January 28, 2013, 06:28:03 PM »
Hi Michael,
Thanks for pointing me in the right direction - looks like Audacity has the facility to import Raw audio, and is free. I'll download and give it a try.
Cheers!
Stewart
Microphone blog
ruairioflaherty
Re: Recovering corrupt wav files? Pro tools
« Reply #3 on: January 28, 2013, 09:08:18 PM »
Thanks loads
Stewart
Hi Stewart,
I had exactly the same issue on a session about 6 months back, I tried the raw approach suggested by Kingston to no avail.  Weirdly mine was also a second kick mic, a sign from gods of audio that we are overdoing it? :-)
The solution was wonderfully simple - Wav Saver by Rail Jon Rogut.  Bottom left hand corner on this page - http://www.railjonrogut.com/
See a thread about it here - http://prorecordingworkshop.lefora.com/2011/02/07/raise-a-toast-to-rail-jon/
Ruairi
peterc
« Reply #4 on: January 29, 2013, 01:48:35 AM »
What you could also try is to copy the file to another drive, and import it back into the session.
This has worked for me in the past but is not bullet proof.....
Peter
If opportunity doesn't knock, build a door.
zebra50
« Reply #5 on: January 29, 2013, 03:48:11 AM »
Thanks guys,
I did try copying to another drive - that has also worked sometimes for me in the past but not this time. I will give wav saver a go.
 > Weirdly mine was also a second kick mic, a sign from gods of audio that we are overdoing it? :-)
I normally use an RE20 (or RE320) in the kick, and lately out of habit I have been popping in a Shure SM91 beta too. I've lost the RE20 track. Right now I am glad that I have the other mic! At least I can trigger something if I can't get the RE20 back.
Nothing succeeds like excess!
Stewart
Microphone blog
mrclunk
« Reply #6 on: January 29, 2013, 09:17:57 AM »
Wav saver's saved my bacon before! Definitely worth a try.
Samuel Groner
    Zürich, Switzerland
« Reply #7 on: January 29, 2013, 11:11:20 AM »
zebra50
« Reply #8 on: January 29, 2013, 12:28:23 PM »
Wav saver did the trick instantly and perfectly. Many thanks for all the ideas. I am very happy!
Microphone blog
Ashishan
« Reply #9 on: April 03, 2013, 05:30:37 AM »
In situations like this and if all else fails, try Linux versions knopix or puppy. Both will load from cd as a virtual install on any computer. I found out about this trick a few years ago. All wav files in a project for some reason had corrupted data at the end of the files and thus would not play on anything. Looked like a total loss. After giving up a friend gave me knopix and unlike anything else it was able to slowly (4 ½ hours) extract each file and rebuild it. Problem solved. It also seems to work for broken drives, again slowly but it succeeded where numerous computer geeks failed.
Whoops
« Reply #10 on: September 05, 2013, 12:04:43 PM »
Thanks loads
Stewart
its a common problem in Protools 8 and Protools 9 versions.
Use an app for MAC called Wav Fixer 8.0.3,
it fixes the wav metadata and then the files are fully functional
Saved me countless of times
all the  best
zebra50
« Reply #11 on: September 05, 2013, 04:57:51 PM »
Just as Ruairi suggested above! It worked a treat.  ;)
Stewart
Microphone blog
leadbreath
« Reply #12 on: April 21, 2016, 06:11:41 PM »
cool...
f**k marlbro's and weed ill stick to smoking germanium and silicon
Last post February 16, 2005, 03:44:36 PM
by pucho812
Last post December 29, 2009, 11:22:43 PM
by EmRR
Last post May 28, 2010, 10:51:19 AM
by jdbakker
Last post May 27, 2010, 10:19:04 AM
by strangeandbouncy
