Anyone have a microphone capsule to spare?
gentlevoice1
Aarhus, Denmark
Hi  ;)
I'm in the process of designing a microphone amplifier circuitry for a B&K 4133 capsule but before venturing into using the 4133 I'd prefer to try out things on another capsule of some kind.
Might one of you have a capsule that you do not use - but which works - and which you can spare (I live in Denmark)?
I'd be pleased to give you a wine (or something to your liking) for a usable capsule.
Greetings,
Jesper
Oups - a P.S.: It must be a capacitor microphone so that it at least to some extent resembles the B&K.
Are you going to put 200V on it which is the correct Vp for 4133?  This will severely limit your choice of capsule.
Hi Ricardo,
No, I won't put 200 Volts on it. I'll put what is adequate for the capsule - it doesn't matter so much in relation to the circuitry I'm going to use. I'd just like to experiment with shielding, get an impression of noise levels etc. before using the B&Ks.
Greetings,
Jesper
For experiments with noise and shielding etc, you could just put in a good-quality capacitor of the value that you expect your future capsule to be.
Something like 30pF for a small diaphragm and 82pF for a large.
That said, I think I have a capsule or two somewhere that I can lend you for your initial experiments.
Jakob E.
Hi Jacob,
Much appreciated :) I'd like to be able to borrow a microphone from you at some point in time - will just consider whether to start with the capacitor or go with the microphone from the beginning.
Hope life is well  ;)
Jesper
