Sonic Foundry
Member
- Joined
- Feb 15, 2013
- Messages
- 6
I'm building the hairball audio 1176 rev a right now and everything was going good (passed audio all the way through) but I wasn't getting any compression so I did a little digging and it looks from all the pictures of the completed pcb that I mounted the trim pots at a 90 degree angle to how they're supposed to be mounted. I would assume this would cause the unit to not compress because the trim pot is essentially a variable resistor and I have no way to adjust q bias.. So I tried to remove the q bias trim pot and one of the leads broke . My local electronics store has a 5k but it calls for a 2 k.. Would a 5 k hurt anything or cause problems? am I right in assuming that this is why the unit isn't compressing? (Im noticing a very tiny bit of compression at 20:1)
