HellfireStudios
I am cloning the Telefunken AR-51 and have read its power supply is 140 volts instead of the more common 120 volts most classics liked to see. I intend to change the 1N47__ diodes to ones closer to the Telefunken's voltage. I have 2-68V 1N4760's and 2-75V 1N4761's. That leaves a supply voltage of 136 volts or 143 volts. If 140 volts is my intended goal, should I go with 136 or 143 volts? Thanks.
-James-
-James-
