LA2A - is EQ'ing after it normal practice?
« on: February 22, 2013, 07:26:43 PM »
After getting familiar with the D-LA2A, I have been impressed and enlightened. Critical listening is an endless degree in itself.  The more carefully I listen, I notice more and more of what is and isn't happening.
Anyway, I believe I'm hearing a softening of the recorded material passing through it. Not softening in terms of dynamics, albeit that's normal of course but in frequencies.  Is it common practice to e.q. after using compressors like the LA2A, 1176 and their DIY variants? There appears to be a dip in airy-ness a little or a darkening.
I especially find it interesting what it does to transients. I wish there were operating tips/techniques/instructions to get better at operating this thing.
pucho812
Re: LA2A - is EQ'ing after it normal practice?
« Reply #1 on: February 22, 2013, 09:51:15 PM »
that is like asking long is a piece of string. If the sound you hear requires correction aka eq then use it. I find that I usually run a compressor first most of the time before an eq la2a or other type compressor.
as for tips and tricks there may be some in la2a manual found on the universal audio website. Other then that I have to ask what eq setting you do afterwords and such...
As always remember sound is so dependent on what the musical style is.
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
« Reply #2 on: February 25, 2013, 04:06:14 PM »
It was common for passive eq's to be used after an LA2A...back in the day.
Whoops...that wouldn't makes sense to to gen-x'ers. Or wait, the peter pan generation!!!?
edit: Wait, i'm a gen-xer?  :o
« Last Edit: February 25, 2013, 04:10:13 PM by desol »
pucho812
« Reply #3 on: February 25, 2013, 04:23:40 PM »
so I told the lady I got your make up gain, right here.  Then I pointed to a preamp. ;D
abbey road d enfer
« Reply #4 on: March 06, 2013, 11:45:04 AM »
It's common practice using EQ on a compressed signal. The ultimate being EQ on both input and output. The pre-comp EQ shapes the way the compressor acts. As compression always changes the spectral distribution, it is necessary to compensate it with post-comp EQ.
Some of us have spent a lifetime or two understanding and mastering these beasts. Consider yourself lucky that you can learn from the ancients with just a few mouse clicks. Some kids actually pay a lot of money to go to school and learn it.
martthie_08
« Reply #5 on: April 07, 2013, 07:31:45 AM »
what transformers are you using in your D-LA2A? I have had my unit side by side with another build and they sounded dramatically different! Eventually you will find out what the unit does to signals passing through it and you will have a gut feeling on which sources to use it on and on which not to use it on. A lot of things will end up being eq'ed anyways so if you like the compression characteristic use it with an EQ. My particular unit is not flat, it has a little bump in the upper mids and a little dip in the lower mids which helps to clear things up. I find you can really get away with loads of compression, just don't listen in solo mode :-)
kato
« Reply #6 on: May 08, 2013, 07:02:25 PM »
I found Urei's 1176 manual helpful in learning how to use my clone. You might find the LA2A manual useful too.
« Last Edit: May 08, 2013, 07:12:39 PM by kato »
burglar
« Reply #7 on: May 09, 2013, 01:25:17 PM »
When i used them in the past it was usually third in the chain.  Eq, compression (something with good attack release...1176) then the LA2 to squeeze it.  As you said about what it does to transients.  I'm not keen in that and a bit of control with another comp before hand works well.
I mainly used them on vocals and bass in this fashion and it has a wonderful way of bringing things into the foreground.  They're good at tickling strings as well.
chaellus
« Reply #8 on: July 25, 2013, 05:19:36 AM »
if you eq before it tames what you eqed provided you didnt boost some annoying frequencies in which case it will only make that stand out more. Plus whatever you eq into the compressor your also adding noise from the gain of the eq unless its a passive eq.
so look at it this way, if you eq pre compression you tame your settings if you eq post compression its to make up for what the compressor took.
Last post December 09, 2008, 05:54:27 AM
by Richon
Last post February 19, 2009, 07:01:04 AM
by hotbaby
Last post June 12, 2009, 11:47:29 PM
by idylldon
Last post March 21, 2013, 07:08:01 PM
by jplebre
