Strawtles said:Thank you CJ
I have not yet bought the transformers, but in the site (Carnhill/Audio Maintenance) I don't find these specifications
Strawtles said:Someone can explain to me the difference between 10K:600 and 15K:600 transformers in a tube preamp output (ECC88)?
I know that with a higher ratio there is less output signal, but there are differences in sound quality?
Strawtles said:As CJ said I want only to compare transformers for the same circuit: the EMI REDD 47
I know that the Sowter replacement is a 10K:200 (with a ratio of 7:1) but as I want to use a cheaper transformer (Carnhill) I asked if it is better the 9600:600 (4:1) or the 15k:600 (5:1)
The last one has a higher ratio but a different input impedance than the original one
no, what you said was "wait for PRR" ;D
CJ said:Strawltes, what kind of E88CC are you going to use?
JJ, or NOS Tele, Mazda,Phillips...
6DJ8? 7308? 6BQ7a? 6922? 6BZ7?
we need the cathode voltage to do a load line, anybody with a Redd 47 out there? what is the cathode voltage?
