electric_diaries
Hi guys I am just knocking up a 2 channel discrete preamp and need some help finding a simple power supply schematic using only one transformer (if possible) to get +24VDC and +48VDC. I searched the META and while there is a lot of talk about different ways to do it, I couldn't find a decent schematic. My current idea is to use ONE transformer with 2 x 24VAC secondaries.
One of the 24VAC secondaries I will use to make 24VDC (single ended) for my amps. A two stage design using amps similar to the Neve BA338.
The other 24VAC secondary will be used in a voltage doubler to make 48VDC for the phantom power.
My questions are:
A) Is this ok? Hah funny question I know, but I have always used separate transformers for the phantom and B+ voltages. Although I know that the secondaries aren't connected I just wondered if there would be any other interference.
B)Is there a better way to do it? From memory these amps only really draw around 40ma max and there will only be 6 of them (2 to drive the meters) so I don't need the big heavy duty power supplies that I usually make for multi channel stuff.
Here are the schematics that I plan on using. If anyone has suggestions (especially if to simplify) then please feel free to post! I feel like I might be going over kill for just a 2 channel thing.
http://powersupply88.com/24-volts-power-supply-at-2-amperes.html/24v-power-supply-at-2-a
http://lh6.ggpht.com/_FdGFE8NBDgc/S90YNITcvnI/AAAAAAAACeE/wx3W8K-yRUw/48-v-microphone-supply-circuit-diagram.GIF
Thanks a bunch! - Benjamin
My questions are:
