passive Pultec type EQ and G9 for gain makeup
matthias
germany / frankfurt
hi,
one of my next project should be a passive pultec style eq, maybe with some more frequencies and a G9 for gainmakeup....
I would use a ll5402 on the input of the passive eq stage, as it is done in the Gyraf Pultec.
Can I connect the unbalanced output of the eq circuit directly to the "instrument input jack" or should I better use an extra transformer at the eq output and the LL1528 at the G9 input ??
mat
thank you jakob...
and ... if I wanted to connect the passive eq section to another amp...
a 1272 for example...
what kind of output trafo do I need in the eq to go balanced into the amp ??
thanks,
mat
can I connect the unbal. eq output to the balanced trafo input of the amp
(pin2 connected to gnd) to get the coloration of the transformer into the signal ??
thanks,
mat
