Crimson Audio CT-2385 API Output
CJ
GDIY Supporter
California
finally figured out what was wrong with this xfmr that somebody sent me a while back,
i believe this is an API type output, quad wound, we will take it apart and see,
problem was a short between coils, an unlucky short, red to yellow, 2 Finish leads that were supposed to be isolated were tied together, which means if you series connect red to orange, you will be shorting out the org-yel coil, these things are like resistors, brn is a start, red is it's finish, org is the next start etc,
here is the Main Offender, which is also a cool album by Keef Richard>
air dry epoxy means that you heat the core up and slice it quick with a knife before it cools of, old school xfmr lams can be used, but you bend up the lams when you pull a newer unit apart as there is sticky epoxy instead of wax,
somebody was in a hurry when they wound this,
Starts are - red - yellow - blue = gray
Finish leads are are  brn - org - green - pur
grab 4 and spin like crazy,
300 turns of non braided quad wire, looks like a DIY twist job, twisted wire is very expensive as they have to meet a spec of say, 2 1/2 turns per inch, or some other number, this looks more random,
closeup of quad wire,
so this is bobbin wound on a sq. stack of 625 EI, 625 means 0.625 tongue width, so 50 EI would have a half inch tongue, 175 EI would have a Gene Simmons tongue,  :D
DCR was 9 ohms per winding,
inductance per each wind at 2 to 20 volts (low freqs drag down the sig gen,)was
1.6 H at 5 Hz, 1.7 at 10 Hz, 2.39 H at 40 Hz, 3.45 at 100 hz and 0.8 H at 1K.
that should be it, real easy coil to DIY, twist  the wire with a hand drill if you have access to a big room, takes about 99 feet of wire, wind it on the bobbin by hand, 300 turns is cake.
