today we are going to rewind a V72 choke.
these chokes are very unique in that they use a 3 chamber bobbin, tons of turns,
and a lamination that will have you guessing as to how to take the choke apart,
since this choke caries DC, it has to have a gap.
if you move the gap 1 or 2 mils, inductance will change a lot.
temperature or mechanical shock can upset the gap, but there is a clever solution,
you stamp a lam with a built in gap,
but how do you get the coil on? well, you just bend the tongue a bit.
after all the lams are in place, you stick a shim under the coil to lock the choke together,
the only disadvantage is that you throw away some material,
but if you want a fantastic product, you do things like this,
see if you get it by looking at this pic>
