Ok, installed my new RK-47 (along with almost all the Jim Williams mods), and....
It sounds great. Much fuller low end, and fuller low-mids. Less
piercing highs. Much smoother overall. I can hear the 2-8kHz
bump, but it's not too bad. It's definitely a better mic, and sounds
damn good to me.
Having said that, I still think the original mic could be useful in
certain situations. The original capsule with the upgraded
electronics was more shrill, but that too, could be useful. The
excess brightness or presence could be something that you
would end up EQing in anyways, to cut through a mix.
The original capsule is a small diameter one, right? I was thinking
it would be fun and interesting to build another circuit for it, and
find another body for it, and make yet another mic. Perhaps the
same Schoeps circuit, but with caps optimized for lower frequencies
(C3, C4 at 1uF), and more high frequency roll-off (maybe larger
values for C15 and C16), and maybe the capsule would be
more useful, and flatter. Although I'm sure there's a limit to how
much low frequencies you can get out of a small diameter capsule
versus a large one.
Perhaps someone has a better idea about how to use the original
capsule? A circuit that would match it better than the Schoeps?
Thanks for your time.....
damn good to me.
versus a large one.
