Hello All,
I've been thru the various zero field frafo discussions over here but would like your insight in the following:
My EMT mixing console has Beyer line in trafos (BV3XX 001 081) with turns ratio 1:1 and a specified secondary DC resistance of 7.9KOhm.
These have a pad in front of them, but still exhibit distortion (mainly 3rd order) which is two orders of magnitude higher between 20 and 100Hz compared to 1KHz.
I have one unused opamp section left on the PCB; what would be the best basic schematic to try and cancel out the sec DC resistance?
I've read some claims that this high a DC resistance would be impossible to compensate, others say it should be possible.
Any help appreciated; I'll post distortion plots of results before and after.
Best Regards,
Rogy
Best Regards,
Rogy
