Re: Neumann M49 Clone : Build Thread Puck Style (TLM49 Conversion To M49 b-c)
« Reply #140 on: September 18, 2014, 10:46:23 AM »
Yes, poctop's M49b with Peluso capsule (later killed in an accident) and AMI T49 tranny, sounded absolutely gorgeous.
Which Peluso capsule was it, CEK-47 or P-K47, I just noticed there are two different ones...
« Reply #141 on: September 18, 2014, 12:42:28 PM »
it was the P-47,
Dan,
« Reply #142 on: September 20, 2014, 06:44:19 PM »
On the input of my triad VP-T230-110 I'm applying 120 (that what my main is) and on the out I'm getting 136AC. Is that normal?
Im tying up on the in Blue and Violet then Gray and Brown, and on the out red-yellow and black-orange. That should be good right?
When I hook that up to the AC in of the board, with no load, just testing the power supply, I'm getting this:
B+ the lowest I can adjust with the R8  trimmer is 129.4DC
H+ the lowest I can go with the pot is 20.15DC
Polarization I can get 129.1DC for 8
                                                   64.5DC for Cardioid
                                                           0DC for omni
Is there a problem? if it is, Where should I look into?
« Reply #143 on: September 20, 2014, 09:38:34 PM »
Another Newbie question; Do you cut the pins/leads 8 and 4 off the tube?  (5840)?
Not Clear on the pictures,...
« Reply #144 on: September 21, 2014, 10:49:25 AM »
                                                   64.5DC for Cardioid
                                                           0DC for omni
if you have no load this is normal to see higher voltage  , this is a passive PSU,
so when the mic is connected it will load down to proper value for adjustement ,
« Reply #145 on: September 21, 2014, 10:50:05 AM »
yes you can cut them as they are redundant ,
Dan,
« Reply #146 on: September 21, 2014, 10:52:16 AM »
Thanks Poctop!!!
« Reply #147 on: September 21, 2014, 04:59:48 PM »
Just Double check:
5840 tube:
Pin 1 to FGRID
Pin 2 to K
Pin 3 to H+
Pin 4 - Cut
Pin 5 and Pin 7 Tied together to A
Pin 6 toHG
Pin 8 - Cut
Right?
THANKS!
« Reply #149 on: September 25, 2014, 12:40:12 PM »
Hello Everybody,
Do you know any good source for the round bodies? Just like the original ones?  Like Poctop's prototype? Where I can use it with Yokemount and Binder series 691 - 7 pin connector?
« Reply #150 on: September 25, 2014, 01:32:41 PM »
Hello Everybody,
Contact AMI and ask for Dennis,
or Here   http://groupdiy.com/index.php?topic=52563.0
Dan,
« Last Edit: September 25, 2014, 01:51:52 PM by poctop »
« Reply #151 on: September 30, 2014, 02:02:35 PM »
Ok I got all together but the body and capsule. Still debating myself about what capsule to use.
This is the problem I have. I think my voltages are off, when I connect all together, this is what I got:
Any Idea What got wrong?
« Reply #152 on: September 30, 2014, 02:18:24 PM »
Very Very Nice Build , Congrats so far,  8)
could you let me know wich picture represent wich voltage , I can guess quite easilly but it would be so much better for this thread  8)
did you adjust each of the voltage with the corresponding Potentiometer, ex.. B+ H+, Bias Pot
as far as i can tell you are pretty smack on the value , for B+ backplate and bias what about the heater at 6.3V
What tube is it , what is the 1.68V on the psu reading ?  is this the heater voltage ?
Let me know,
Dan,
« Last Edit: September 30, 2014, 02:22:03 PM by poctop »
« Reply #153 on: September 30, 2014, 03:05:00 PM »
Thanks Dan!
Voltages on the Mic:
K= 1.612V - Pic 1
A = 122.4v -  Pic 2
H+ = 1.623 - Pic 3
Pin 5 = 123.8v - Pic 4
#4 power supply = 1.683v - Pic 5
#6 Power Supply - 059.7 - Pic 6
#5 Power Supply - 123.7v  - Pic 7
I can control A Voltage on the mic with R8, but that is the lowest it goes.
I can control K on the mic and #4 on Power Supply with the Pot.
This is the tube I use:
Power Supply ( Used the box before for something else,>..)
« Reply #154 on: September 30, 2014, 03:40:41 PM »
Thanks Dan!
K= 1.612V - Pic 1
A = 122.4v -  Pic 2
H+ = 1.623 - Pic 3
ok disconnect the mic immediately,
the problem is the heater voltage you have no emission hence no plate current that is why the Anode voltage is so high,
i think you have issue with the wiring of the 20 VAC traffo ,
how did you configure it ,
show me how it is wired or draw a little somthing ,
only this part is suspect.
Best ,
Dan,
« Reply #155 on: September 30, 2014, 04:00:11 PM »
Have A Look at this ,
Connect pin 5 and 8 to PSU PCB. ( Valid For North America )
Dan,
« Reply #156 on: September 30, 2014, 04:01:04 PM »
OK, This is how I have it wired:
When Is not connected to the board I'm Getting 25.61V on 5 and 6
« Reply #157 on: September 30, 2014, 04:18:25 PM »
Dan,
Yep That is what I have!  Sorry i wrote 6 in the picture!
« Reply #158 on: October 01, 2014, 09:13:36 AM »
Best ,
Dan,
Any other idea?
Thanks Dan for helping!
« Reply #159 on: October 01, 2014, 09:19:13 AM »
Best ,
Dan,
Any other idea?
what is the voltage up the heater when you disconnect the mic ,
D
Last post April 28, 2020, 04:32:56 AM
by TillM
Last post June 01, 2018, 06:15:23 PM
by hop.sing
Last post December 25, 2019, 07:13:13 PM
by Delta Sigma
Last post March 07, 2019, 07:08:13 AM
by alhe
