Re: Neumann M49 Clone : Build Thread Puck Style (TLM49 Conversion To M49 b-c)
« Reply #560 on: January 12, 2021, 11:59:03 AM »
Are you measuring in the power supply or in the mic?
All measurements are in the mic. The rear diaphragm measurements are at the RD connection point referenced to ground.
Josh
« Reply #561 on: January 12, 2021, 01:21:30 PM »
I just tested pin 6 on the mic PCB, referenced to ground:
F8: 116V
C: 57V
O: 0V
That's obviously correct. Should I be seeing those same voltages on the RD? That doesn't make sense given the 250M series resistance between pin 6 and HZRD. I'm not sure why somebody said RD voltage is supposed to be that?
« Last Edit: January 12, 2021, 01:33:21 PM by JMPGuitars »
Delta Sigma
« Reply #562 on: January 12, 2021, 06:23:54 PM »
That's the last place you can check the voltage properly. 0, 2 and 4 volts seems right. If your DVM input impedance is 10M, in parallel with 250M puts you somewhere around 4.5V in fig-8.
Neil Fitzpatrick
« Reply #563 on: January 12, 2021, 07:37:00 PM »
That's what I figured, so that's all good. Now I've got to figure out what's going on after that point. I installed the capsule and I'm getting very low output in all modes, but F8 is definitely louder than the others. Cardioid doesn't seem to work. Tapping the screen is louder than yelling at it. I'm guessing a connection issue somewhere.
« Reply #564 on: January 12, 2021, 08:18:24 PM »
Hahahahahaha. Well, I figured out the problem. I took some photos with my 42MP camera and zoomed in. Turns out, I didn't have to zoom in to see the problem. Can you see it?
Delta Sigma
« Reply #565 on: January 13, 2021, 10:59:09 AM »
Not sure. Backplate screw?
Neil Fitzpatrick
« Reply #567 on: January 13, 2021, 07:16:51 PM »
What's the general consensus regarding B+ with the M49b? I'm at 116V right now. What differences do people hear raising it to 118 or 120?
« Reply #568 on: January 13, 2021, 09:52:21 PM »
For me it has to do with the capsule. In my 251 build I liked the b+ 118 when using the BeesNeez ck12 and 110 when using the Tim Campbell. As far as the 49 I use 115v cause that’s what is specified for the phaedrus ac701.
« Reply #569 on: January 14, 2021, 08:06:38 PM »
I'm using a BeesNeez M7 capsule, with an AMI T47 transformer, and a 5840W NOS tube. I guess I should just experiment with it.
« Reply #570 on: January 14, 2021, 11:59:19 PM »
Yes that is the best way. I have found that in most designs when you go lower the sound gets kinda more compressed with an emphasis in mid frequencies..more reedy, and as you increase the b+ the sensitivity increases and the sound becomes more “electric” and detailed...more modern if you will. That’s not a scientific find but rather a personal observation on my builds.
« Reply #571 on: January 15, 2021, 07:55:52 AM »
Thanks! That's exactly the kind of feedback I was looking for before experimenting.
« Reply #572 on: January 16, 2021, 12:31:12 PM »
I like cloning the Neumann NKM type supply for mic PS builds.  I especially like the way the HT is regulated by a VR tube (150B2 or US type 0A2) right off the rectifier through a resistor.  Additional RC pairs on the HT will drop the 150 vdc off the regulator and deliver clean stable voltage to the mic.  The heater voltage can be regulated using a LM317 or 7806 type circuit, or a series pass.  Instead of stabilytes in the NKM, rechargeable AA type batteries work.  Use enough of those in series for the heater voltage used.  Rechargeable batteries have lots of capacitance in a small volume.  Lots of possibilities; simple and inexpensive.
Note the 0A2 and 150B2 regulator tubes are not pin compatible.  Wire the socket accordingly.  Always use a small series resistor if batteries are used for final LV filtering.
« Reply #573 on: January 17, 2021, 03:47:22 PM »
After plenty of experimentation and component swaps the mic is done. No more tweaking...sounding absolutely fantastic. The final version is:
-Danys D7 capsule ( wow...fantastic capsule)
-Moby bv11 7:1
-phaedrus ac701
-Cornell doubilier MP in wax 1uf 200v coupling cap
-wima tfm 0.01uf 400v caps
-Elna silmic 22uf cap
Calibrated at 115v b+ and 3.9v h+.
Very happy with this. Wonderful on both male and female voices and really nice on instruments.
egroys
Hello!
I am planning to make this my first tube mic build and wanted to clarify if I should be building a PSU or if there is a way to mod chunger’s TPS100?
If so, I would be very grateful for any pointers and to determine additional components I would need to achieve that! Does this change if I go with a 6S6B-V vs. 5840W?
Thank you in advance!
« Last Edit: March 19, 2021, 02:14:13 PM by egroys »
Delta Sigma
I don't think Dany's power supply PCB will fit a TPS100. If you build an M49b, you will add a choke and you'll need a big box like Collective Cases' mic power supply chassis.
See Dany's Mouser BOM in the first post for power supply components. Note that he includes optional parts like a Hammond enclosure in the BOM. Don't just add to cart, review the BOM.
Neil Fitzpatrick
egroys
Excellent! Thank you!
egroys
So this will be my first tube mic build and I would love any opinions or advice.
My current plan is:
-Chunger’s CU-49 body
-Collective Cases PSU box
-Dany’s D7 capsule
-6S6B-V
-Cinemag CM-6511?
I wanted to find out if I need any alternate components if I want to use a 6S6B-V over a 5840. Is it still wise to use a Cinemag CM-6511 with this tube?
Also, I am still undecided on the b or c version and would appreciate any thoughts.
Thank you in advance!!
TillM
Take the c version!
These version has much lower hum.
For the transformer I would use Mobys BV11.
My current plan is:
-Dany’s D7 capsule
-6S6B-V
-Cinemag CM-6511?
Mobys bv11 is a great transformer.
C version is quieter. Mine is the c version and it doesn’t lack fullness, it sounds big and balanced...extremely quiet too even with a 5840. Now I have a phaedrus ac701 and it is dead silent.
Danys D7 is an awesome capsule for this build. Also try to find a nice MP output cap. Super pups 1uf 200v sound great and they are very affordable on eBay.
Last post March 07, 2021, 03:49:47 PM
by Purplenoise
Last post June 01, 2018, 06:15:23 PM
by hop.sing
Last post March 07, 2019, 07:08:13 AM
by alhe
Last post March 07, 2021, 12:10:33 AM
by athnony
