Re: Neumann M49 Clone : Build Thread Puck Style (TLM49 Conversion To M49 b-c)
« Reply #160 on: October 01, 2014, 09:23:45 AM »
H+ with no mic is 20.89v
« Reply #161 on: October 01, 2014, 09:54:57 AM »
then Something is Pulling too much current ,
I suggest then you install a load resistor between pin 4 and ground to rule out the psu ,
somthing like 47 ohm 1 W , you can stick it between pin 4 and gnd right in the xlr connector on the psu ,
this will load it at about 150ma for 6.3V , then you will be able to rule out the mic or psu ,
Dan,
« Reply #162 on: October 01, 2014, 10:03:15 AM »
Dan,
Thanks Dan. With No mic, How much voltage should I have at H+?
Is there something else wrong?  Pot Wired wrong?
« Reply #163 on: October 01, 2014, 10:08:30 AM »
Dan,
you should be able to adjust the pot for 6.3V at 150ma with no mic connected and the dummy  load installed,
if not then PSU got somthing wrong ,
Dan,
« Reply #164 on: October 01, 2014, 10:57:40 AM »
[q
Dan,
These are the voltages following the schematic:
- After the diodes at C13 - 29.36V
- after R2  - 28.99v
- X1-2 - 28.86v
- X1-1 - 28.57v
- after R6 - 27.93v
-after R11  -  27.27v
- the lowest I can go with the POT is 19.78v
Could not find any leaky cap in the path, all the negative side of them has no voltage
« Reply #165 on: October 01, 2014, 11:15:53 AM »
[q
Dan,
and this is with the dummy load resistor installed ?,
dan,
- after R2  - 28.99v
- X1-2 - 28.86v
- X1-1 - 28.57v
- after R6 - 27.93v
-after R11  -  27.27v
« Reply #166 on: October 01, 2014, 11:23:56 AM »
No, No dummy Load.  So 47 ohm  1w
« Reply #168 on: October 01, 2014, 11:46:04 AM »
Will Get Back. Started Session.
« Reply #169 on: October 01, 2014, 03:16:29 PM »
OK!!!  With the 47Ohm 1W connected from 4 on the board to the body of the XLR I can Adjust just fine to 6.3V!! So it is the Microphone...  What should I check first?
« Reply #170 on: October 01, 2014, 03:31:43 PM »
I had wired the board 1 to 7 with the connector 1-7 corresponding.
Then the cable is wired 1 thru 7 on the corresponding one on the other side. Applied the load on the female side of the cable pins 4 and 7, with the male connected to the Powersupply, and I was able to adjust to 6.3V.
I have wired the male binder to the microphone board 1 thru 7 with reversing pins 3 and 7.  connector pin 3 is wired to the board 7 and connector 7 is wired with the board 3.  Also I do not have any capsule on the board if that matters.
Is that ok?
« Reply #171 on: October 01, 2014, 03:37:01 PM »
Is that ok?
The capsule doesnt matter ,  if you have reversed pin 3 and 7 note that on the psu pin 3 is a sheild lift not a ground so the circuit ground should go on pin 7 , but on the mic boar it says 3 this one is reversed ,  hence make sure you have installed the jumper labeled SHLF on the psu board ,  i have made a excel spreadsheet in this thread to mention this ,
a couple of pages back ,  Let me know if you have installed the jumper SHLF specially if you have inverted it ,
DAn,
« Reply #172 on: October 01, 2014, 03:54:12 PM »
Is that ok?
DAn,
I have the jumper, yes.
After re-checking the mic cable (Gotham GAC-7 Tube) and the Binder connectors, and make sure everything is tight, I put the things back together, and all of the sudden I got right voltages;
PowerSupply:
H+ is 6.04v
B= is 116.0v
Mic:
K is 6.08v  ?!?! ( You have it at 1.6v couple of pages back in your picture)
A is 51.8v
H= is 6.03v
on 5 on the board I got 115.8v
Beside the K voltage, I guess I'm good?
I CAN SEE My Tube GLOW  !!!
« Reply #173 on: October 01, 2014, 04:29:07 PM »
Is that ok?
DAn,
PowerSupply:
H+ is 6.04v
B= is 116.0v
Mic:
A is 51.8v
H= is 6.03v
Yep Always a nice Feeling on this myself
If you can see your tube glow now , you are in business with the heater voltage at 6.03V,
regarding the bias , i am guessing you arew building the M49b correct ?
try measuring between grid and Kathode then as per schematic ,
but the most important is your plate voltage that you got right
IMHO,   put a capsule and Enjoy,.
DAn,
It is M49b. Measuring exactly like this:
« Reply #175 on: October 01, 2014, 06:27:27 PM »
Seems like the H= and K are having the same voltage now.
When I measure between HG and the K or HG and H= it is 6.20V
If I measure between Fgrid and H= and Fgrid and K it is 0.93v
« Reply #176 on: October 02, 2014, 08:20:50 AM »
all Normal if you are tackling the M49b , if you look a the schematic  you will understand why,.
Dan,
Winetree
« Reply #177 on: October 05, 2014, 05:54:20 PM »
I got an e-mail that Rigglers bodies are shipping,
I have to decide on a mic transformer using the 5840 tube.
I'd like to save some money and use the T-49, but if the BV's are better, I'll pop for those.
Any real use  comments on the BV11A, vs. BV11R vs. the T-49.
Winetree
« Reply #178 on: October 26, 2014, 05:51:36 PM »
Just checking to make sure.
When using the remote pattern switching from the power supply, these two points are connected?
Is there a diagram for wiring the 7 pin XLR on the mic to the  mic's round P.S.B.s?
« Reply #179 on: October 26, 2014, 06:16:30 PM »
yes they are connected this is a cardiod only switch when off.
check here for cabling hints,
https://io.groupdiy.com/file/gdiy-2017/u/39511/58d02819943e5.xlsx
best,
Dan,
Last post April 28, 2020, 04:32:56 AM
by TillM
Last post June 01, 2018, 06:15:23 PM
by hop.sing
Last post December 25, 2019, 07:13:13 PM
by Delta Sigma
Last post March 07, 2019, 07:08:13 AM
by alhe
