Winetree
Re: Neumann M49 Clone : Build Thread Puck Style (TLM49 Conversion To M49 b-c)
« Reply #180 on: October 26, 2014, 07:01:56 PM »
I'm going to have to open a Microsoft account to see the above link. Don't want to do it.
Any other way to get the wiring?
mgronroos
« Reply #181 on: October 26, 2014, 09:54:03 PM »
Hey Winetree,
Check the enclosed pic, I too a screen dump from Poctop's Excel.
(Needed it myself.)
Michael
If you can't sample it, it doesn't exist.
« Reply #182 on: November 04, 2014, 12:49:14 PM »
FINALLY Got the body and the Thiersch M7 Blue capsule!!!
VERY Excited!  So, where do I wire the front, back and the pole wire?   I'm missing that somehow...
THANKS!
« Reply #183 on: November 04, 2014, 01:04:35 PM »
THANKS!
Best Dan,
« Reply #184 on: November 10, 2014, 11:15:43 PM »
Done!
Microphone sounds Great!!!
I'll post some pictures and samples soon, so busy at the moment.  So far, used it on vocals, cello, and acoustic guitar and love it!
One question;
I have built a U47 out of the oliver's kit at tab-funkenwerk, and K49 capsule.  Comparing it to the D49, D49 is about 15 db lower on the output. Is that normal?
« Reply #185 on: November 11, 2014, 08:03:56 AM »
Done!
One question;
Thanks KMozart glad you finally made it , coming from you is an honnor to receive such a feedback on this mic, for sure love mine as well,  yes the M49 is lower output than Oliver 47 and also it will be a little lower output with M7 instead of K47-49,
if you have built the 49c over the 49b there also a difference in output, 1 is lower output than the other can remember wih one
IIRC the 49b is a bit lower output .  it should be a little hotter then a U87i or nearby, that is what it is given that nice color as well, <
so you dont have to worry if the all the voltage are correct B+ Bias , Heater and capsule Polarisation voltage and mainly that
your transformer is hooked up right. alway good to check  ;)
Edit : if it sounds good then your transformer is hooked up the right way  ;D
Dan,
« Last Edit: November 11, 2014, 08:17:31 AM by poctop »
Phrazemaster
« Reply #186 on: December 09, 2014, 03:51:52 AM »
Dany I have a question. On the prosound forum Oliver made the following statement about the 5840 vs the 701:
"It is a EF732 aka 5840. It is in no way similar to an AC701 but easy to obtain, most of them are usable right out of the box and the impedance matches the BV11 with a 2.2k cathode resistor.
There are at least over 500k of those tubes out there and not the best microphone tube by design, it is something that does get the job done if you just want a good sounding DIY project.
EC70, 71, EC1000, AC761, etc. ?????
There is no tube that has identical characteristics with reference to technical data, nor sound, noise, etc.
Best regards,
Oliver Archut"
(Find discussion here: http://repforums.prosoundweb.com/index.php/topic,32454.30.html)
OK so does that mean I should use a 2.2k cathode resistor since I have a BV11 former?
If so, where/how would I wire it in, or would it replace a component on your pcbs?
Thanks in advance,
Mike
** * Kablooie!
« Reply #187 on: December 09, 2014, 11:08:03 AM »
Best regards,
Oliver Archut"
...and it should also be noted that Oliver implemented that very same 732 (5840) submini in his design for the Telefunken RFK AK-47, and later his own Blackspade UM17, both mics of which he described as being U47/M49 influenced...
« Last Edit: December 09, 2014, 11:11:37 AM by kidvybes »
micaddict
« Reply #188 on: December 09, 2014, 05:15:08 PM »
Plus it's in many Brauner mics.
« Last Edit: December 09, 2014, 06:12:27 PM by micaddict »
0dbfs
« Reply #189 on: December 10, 2014, 05:38:26 PM »
I got an e-mail that Rigglers bodies are shipping,
I have to decide on a mic transformer using the 5840 tube.
I'd like to save some money and use the T-49, but if the BV's are better, I'll pop for those.
Any real use  comments on the BV11A, vs. BV11R vs. the T-49.
I had some T49's and then tried the BV11R. After that I have swapped BV11R's into all of my "49 mic's" except for the ones where I use Max's BV11's and I would use either Max's or the BV11R. Especially if you have installed a premium capsule.
jb
Music is everything!
Audio is everything else!
Phrazemaster
« Reply #190 on: December 14, 2014, 10:15:05 PM »
Hey gang I have 2 questions, probably for Dany...
1) If/when I ever pop for a real AC701, will it drop in, or will I need to adjust voltages etc?
2) I want to move to England, from USA, to be with my lovely gf. That means I want to make my DIY project PSU's Europe-friendly. I was thinking of making it dual voltage, using a switch like this: http://www.digikey.com/product-detail/en/0033.4504/486-2403-ND/641146
My question is, how hard would it be to implement something like this? Do I need to get two different torroids, and two different heater transformers as well, all within the box? Or is there a more elegant way of handling this? Sorry; I love DIY'ing but electronics and I are not always on speaking terms.
Thanks in advance,
Mike
** * Kablooie!
Pip
« Reply #191 on: January 04, 2015, 04:02:09 PM »
So it is done X 3! Decca tree here I come.
Equinox D47 Capsule matched X 3. Max K's Transformer. Riggler and TSguys bodies. My own designed and built PCB for swapping out 5840 tubes. Yay!
See Pix. A bit of a rush job with this post sorry I will fix it up when time allows. They all sound great but now the tube selection begins!
Pip
New York City
http://geosonixlab.com
« Reply #192 on: January 04, 2015, 04:05:42 PM »
Wow,
Thanks For that,
this is whip Cream  8)
Pip
« Reply #193 on: January 04, 2015, 04:08:41 PM »
Best regards,
Oliver Archut"
They are a fine tube and there are zillions available. Once again if you want to use the venerable AC701 get your wallet out as you will have to buy several and hope that one is mic grade. They run about $400.00 a piece these days.
Pip
New York City
micaddict
« Reply #194 on: January 04, 2015, 04:14:00 PM »
Well, you only need three.
micaddict
« Reply #195 on: January 04, 2015, 04:26:21 PM »
In all seriousness. Three M49s, that is sick, man!  :o :o :o
Congrats!!!
Phrazemaster
« Reply #196 on: January 05, 2015, 03:50:13 AM »
OK perhaps a basic PSU transformer question; forgive me if this is obvious.
For European connection, using the torrid:
Can connect the windings in Series for 230v for primary. Then secondary can be connected in parallel for output of ~120v?
Forgive me; I'm nervous do you have to have primary in series and secondary in series too, or can mix them as described above? I don't want to piss off any electrons or cause a fire.
Thank-you,
Mike
**EDIT Google is my friend; I found this link:
http://www.electronics-tutorials.ws/transformer/multiple-winding-transformers.html
Apparently this is totally fine. Could I get an Amen from Dany or some other wizard? Electricity makes me nervous! Thanks!
« Last Edit: January 05, 2015, 03:56:05 AM by Phrazemaster »
** * Kablooie!
micaddict
« Reply #197 on: January 05, 2015, 04:59:27 AM »
Seems you picked the wrong hobby.  ;D
Or is it the adrenaline rush you're after?   :P
micaddict
« Reply #198 on: January 05, 2015, 05:23:45 AM »
In all honesty, it makes me nervous, too.
And  you've proven to be braver than me, sofar.
BTW, a little nervousness is OK. It makes you careful, which doesn't hurt in this regard.
Too much ain't good, though. When you lose the steady hand and can't think straight anymore, it really gets dangerous.
Phrazemaster
« Reply #199 on: January 05, 2015, 11:24:21 PM »
Thanks micaddict mr. cheeky! ;)
I agree; it's good to have a healthy fear or respect of this hobby. I read recently that tubes can kill, so although I've been very careful and have not gotten killed so far (I think), I will continue to have a healthy respect for what I'm doing. So I don't get deader.
You know, I could of died already and didn't know it. We're all scraping after creating clones when here in the afterlife all we hafta do is order us up a brand new M49 from the heaven factory from Mr. Neumann hisself.
Go figger!
Mike
** * Kablooie!
Last post April 28, 2020, 04:32:56 AM
by TillM
Last post June 01, 2018, 06:15:23 PM
by hop.sing
Last post December 25, 2019, 07:13:13 PM
by Delta Sigma
Last post March 07, 2019, 07:08:13 AM
by alhe
