I like cloning the Neumann NKM type supply for mic PS builds. I especially like the way the HT is regulated by a VR tube (150B2 or US type 0A2) right off the rectifier through a resistor. Additional RC pairs on the HT will drop the 150 vdc off the regulator and deliver clean stable voltage to the mic. The heater voltage can be regulated using a LM317 or 7806 type circuit, or a series pass. Instead of stabilytes in the NKM, rechargeable AA type batteries work. Use enough of those in series for the heater voltage used. Rechargeable batteries have lots of capacitance in a small volume. Lots of possibilities; simple and inexpensive.
Note the 0A2 and 150B2 regulator tubes are not pin compatible. Wire the socket accordingly. Always use a small series resistor if batteries are used for final LV filtering.
