Bv. 14155 OPT
CJ
GDIY Supporter
California
always something different with every transformer take-a-part,
this guy has a weird snap in lam that features an interesting tongue,  :-*
other than that, it is pretty straightforward, pri-sec winding structure on a single chamber bobbin,
if anybody knows what this came out of that would be cool,
has center tapped pri and sec,
pretty flat freq wise, however, at 5 hz it sucks 13 ma which is a lot, 1 ma is more typical for small audio stuff,
big peak at 114 kc, jumps from about 5 volts out to 35 volts, then takes the Nestea plunge into oblivion,
those lams have a 1/2 inch tongue but will not match up to any EI lam, so the bobbin is unique to the lams which means it would be hard to duplicate nowadays>
