SSL ring nut tool?
jwhmca
USA
Hi Guys,
I'm trying to find the tool or the name of the tool type that removes the "Ring nut" or whatever it's called from the "Pots" and switches on a SSL 4000.
I have the sifam collet tool, but then underneath the knob is another nut...
Not sure how it's called but you can buy it from ssl. If it's not custom, maybe someone knows where to get one cheap.
Hope it helps
I have the collet tool... underneath the sifam knob there is another "ring nut" What tool takes that off?
In about a week we should have stock of the tool for Elma ring nuts.... I imagine that is what you will need.... When they are in stock I'll put some dimensions in our on-line store. It is a hollow tube with 2 pins on the end and a "t" bar handle.... the ring nuts that it is designed for are about 14mm across.... they will be about GBP 25
It is lucky that you have the ones for the sifam collet knobs as they are no longer manufactured.
Colin
www.audiomaintenance.com
Colin
Thanks Colin.
I work at a full machine shop... should I make a bunch of the Sifam collet tools? Would there be an interest to buy them?
I simply bought a cheap china quality flat head screwdriver for 1 Euro and modified it with a dremel tool (no problem since the metal isn't really hard :D ). Easy to do and good enough when you are working with sifam knobs only from time to time.
This tool is totally perfect, one end does the collet for the SSL 611 knob, the other end does the nut.
Got this in the S800 sifam knob group buy, we all did back in 2009? And it's made by Selco.
