Hey there,
When we are talking about adding glue to the whole mix, then send a stereo sum to a stereo comp and wield a tiny bit of compression. Now, I've wondered, is that really a glue effect between those tracks or do we simply benefit from a more controlled dynamic approach over all the sources equally? I mean, wouldn't it be the same if that stereo comp was in mono at the end of every track on a console at the same level? Or does a comp really somehow glue those transience together? I would just like to learn a bit more about the analog theory to not always refer to it as glue and actually knowing a little more than that.
Same for the stereo EQ, like a pultec, wouldn't it be the same if there was a pultec at the end of every channel because the level, after balancing, it will adjust itself accordingly anyways? No matter whether it was applied on a much higher level during equalizing the tracks? If we happened to do that on every channel separately?
I'd hugely appreciate it if someone could elaborate on that matter.
Mike
Mike
