CJ Well-known member GDIY Supporter Joined Jun 3, 2004 Messages 15,724 Location California May 16, 2013 #1 this is an input xfmr sent to me from Kid Squid, it is for a transistor amp that has great sound, it runs pretty flat and has great inductance specs, we have the output here also which will be posted tomorrow. here are some pics> Attachments ac1331-a.jpg 296 KB · Views: 37
CJ Well-known member GDIY Supporter Joined Jun 3, 2004 Messages 15,724 Location California May 16, 2013 #2 it uses the same bobbin as the Neve input iron, but only one as it is a single coil job, Attachments ac1331-b.jpg 200.9 KB · Views: 31
CJ Well-known member GDIY Supporter Joined Jun 3, 2004 Messages 15,724 Location California May 16, 2013 #3 this transformer is built up on a 3/8" fat stack of 187 EI, Attachments 187EI.jpg 296.2 KB · Views: 30
CJ Well-known member GDIY Supporter Joined Jun 3, 2004 Messages 15,724 Location California May 16, 2013 #4 here is an inductance vs frequency graph, Attachments ac1331.jpg 35.5 KB · Views: 15
CJ Well-known member GDIY Supporter Joined Jun 3, 2004 Messages 15,724 Location California May 16, 2013 #5 freq chart> Attachments ac1331-freq.jpg 37.2 KB · Views: 18
CJ Well-known member GDIY Supporter Joined Jun 3, 2004 Messages 15,724 Location California May 16, 2013 #6 details: ratio-1:2.3 Z- 600:3.2K wound Pri-Sec pri: 702T #38 fwd wind 7 layers hand wound sec: 1615T #42 fwd wind 17 layers hand wound DCR Pri- 58 ohms DCR Sec- 257 ohms Core- 187 EI 3/8" stack 0.006" thickness Alloy: 80 Ni Stacked:1 x 1 Pri Leads - Start-blu Finish-grn Sec Leads- Start-brn Finish-org Bobbin- black plastic ICM 218 B same as Neve inputs only no lead pins
