I've been thinking I need to build myself a High Voltage supply for tube projects instead of having to build a supply each time I just want to test something out.
I want to make this a very versatile do it all supply that's semi-continuously variable (well, with range selecting switches) from 60-300V. I would also incorporate an LT supply into the same box but that's another story. I have a rough design worked out but the problem is I haven't seen pots that are rated for these high voltages. The basic idea I came up with is to series several, say 30V zeners, and have pots adjust inbetween the multiple 30V ranges, and have a range selector rotary switch select inbetween the series zener nodes (or perhaps I should say the pots coming off each zener junction). The only problem I can see with this plan is the pot voltage ratings... Is there a better way to go about this?
