sahib
As a result of my collaboration with Mr Graham Langley I am throwing my hat on the ring with two new kits under Total Audio Control brand. EQ ONE and MICPRE ONE (launched in the Pre-Amplifiers forum).
The kits are ordered through either WHITE MARKET or directly from www.totalaudiocontrol.com
EQ ONE
EQ ONE is one of the first in our flagship “Designed by Langley” series of pro-audio products. Yes, what is going through your mind is correct. It is indeed designed by the man himself.
The "real"stuff.
EQ ONE follows the topology of the four band parametric equaliser that Graham first used in the Amek M3000 mixing console in 1979. This was later adapted for use in M1000 and M2500 consoles and formed the basis of the equaliser design in many other Amek and Total Audio Concepts consoles.
As with the original design, 12dB/octave swept high and low pass filters are included. The frequency bands have been revised to be more suitable for a stand-alone equaliser and noise performance has been improved.
The topology differs from many other state variable filter designs in that each band is composed of a 6dB/octave high pass and a 6dB/octave low pass filters with different turnover frequencies. This enables the bandwidth to be varied over a wide range and also facilitates the Bell/Shelf switching on the High and Low frequency ranges. The Q control is disabled when in Shelf mode.
The parametric section and the filters section may be individually inserted in the signal path.
A single LED provides indication of signal level. This has quasi-PPM ballistics and illuminates green for signal present (-18dBu), yellow for signals above +4dBu and red for signals above +18dBu.
Typical specification:
High pass filter:       20Hz to 400Hz @ 12dB/octave.
Low pass filter:       800Hz to 20kHz @ 12dB/octave.
High frequency:       660Hz to 20kHz, +/-15dB, Q: 0.25 to 1.5 with shelf mode.
High mid frequency:   320Hz to 10kHz, +/-15dB, Q: 0.5 to 3.2.
Low mid frequency:                  100Hz to 3.2kHz, +/-15dB, Q: 0.5 to 3.2.
Low frequency:      32Hz to 1kHz, +/-15dB, Q: 0.25 to 1.5 with shelf mode.
Frequency response (EQ out):                  +/- 0.5dB, 20Hz-80kHz.
Phase response (EQ out):                      +/-20 degrees, 20Hz-80kHz.
Maximum input and output (100k load):   +27dBu.
Internal operating level/headroom:         -6dBu/+27dBu.
THD&N (EQ in or out, +10dBu input signal):better than 0.05%, 20Hz-80kHz.
Noise (no EQ in), 22Hz-22kHz, RMS, 40 ohm source:  -103dBu.
Noise (typical EQ setup), 22Hz-22kHz, RMS, 40 ohm source:    -90dBu.
Input/output impedance: 20k ohms/75 ohms
The Kit
The kit comes complete with all the components and a comprehensive assembly manual with detailed photographic illustration of each assembly sequence.
http://www.totalaudiocontrol.com/docs/EQ-ONE-ASSEMBLY-MANUAL-9108.pdf
However, as well as having a support thread here, there will also be unlimited e-mail support.
As you can see  the module is a double width type. There are many reasons to it. Firstly, there is quite a lot going on. Keeping it to a single width would require the use of dual concentric potentiometers and result in extremely densely populated and diy unfriendly boards.  But the main reason is to allow user modifications to be made, particularly with the use of input/output transformers.
The input and output stages are kept on a seperate card to allow modifications to be made to these stages to suit your own inividual taste. (For this a proto board is provided as a seperate accesory.)  However, please note that the above specifications  will not be valid after any modification.
Here are some images.
The IN/OUT Interface Card is removed.
The proto board in place.
Main EQ Card.
Potentiometer/Switch Sub assemblies.
IN/OUT Interface Card.
« Last Edit: February 27, 2015, 05:26:54 PM by sahib »
braeden
Re: Total Audio Control EQ ONE, 4 band Full Parametric Equaliser
« Reply #1 on: May 18, 2013, 07:52:26 PM »
Very cool,
Congratulations on the new release!
Braeden
kml23956
« Reply #2 on: May 18, 2013, 08:08:35 PM »
It's unbelievable!!!
gemini86
« Reply #3 on: May 19, 2013, 03:21:16 AM »
Love that I/O module idea. I could see a few people putting that proto board to good use.
- Rodney
"...you better call Kenny Loggins, 'cause you're in the danger zone."
jensenmann
« Reply #4 on: May 19, 2013, 05:38:20 AM »
Great idea to revive this EQ. It´s surely one of the best EQs ever designed.
Jens
Quote from: PRR
The tubes of course don't care what frequency they distort
12afael
« Reply #5 on: May 20, 2013, 02:29:04 AM »
awesome!
heavy metal is the law!!!
kante1603
« Reply #6 on: May 20, 2013, 11:57:04 AM »
Great stuff,congrats!!!
Udo.
kml23956
« Reply #7 on: May 20, 2013, 08:45:12 PM »
How much are you asking for it?
sahib
« Reply #8 on: May 21, 2013, 05:21:36 AM »
Thank you all for your comments.
kml23956,
It is now on sale in the White Market.
http://www.groupdiy.com/index.php?topic=52462.0
kml23956
« Reply #9 on: May 22, 2013, 10:20:03 PM »
Nice...not as much as I thought.
kante1603
« Reply #10 on: May 22, 2013, 10:23:22 PM »
Hello Cemal,
may I ask if both the +/-16 and +/-24vdc rails are used in this build?
From your assembly manual (initial voltages,page 25) I can see that only the lower voltages are mentioned.Meaning for non-51x-builders,must the lower two pins on the card edge be cut off?
Just curious..... ;)
Thank you in advance,
best regards from munich,germany,
Udo.
sahib
« Reply #11 on: May 23, 2013, 04:12:50 PM »
Hi Udo,
You are most welcome.
There is no need to trim the lower two fingers.
The module operates with + - 16V rails as usual.
The + -24V rails are also available on the boxed header for the user modification on the I/O stages.
Kind regards,
Cemal
kante1603
« Reply #12 on: May 23, 2013, 10:04:51 PM »
Thank you Cemal,
that makes sense indeed.
Personally I have 51x racks anyway,so I have sent you a mail asking for a quote  :)).
Good idea to have a block diagram right at the start of the manual btw!
Will there be schematics or pinouts for the headers?
Udo.
sahib
« Reply #13 on: May 24, 2013, 08:43:44 AM »
Hi Udo,
I have received your e-mail.
For the info, the sechematic and the pin outs will be supplied with the kits.
Kind regards,
Cemal
kante1603
« Reply #14 on: May 24, 2013, 09:18:02 AM »
Hello Cemal,
that's great to hear,thank you very much!
Will wait for your quote...and hopefully get started building them soon :D
Have a nice weekend,
Udo.
alexc
« Reply #15 on: July 20, 2013, 04:22:11 AM »
Hey Cemal,
Nice work with Total Audio Control products - looks and I'll bet sounds - top shelf!
Off topic some, but I wonder and look forward to a dymanics module to accompany the Pre and EQ modules.
Can only magine what it would (will) be like  :)
Best regards
Alec
I ping therefore I am
sahib
« Reply #16 on: July 20, 2013, 08:03:51 AM »
Hi Alex,
Many thanks.
We have a list of designs in our program and dynamic control is indeed one of them. Three more modules are under test at the  moment. They will hopefully be available by mid autumn.
Kind regards.
Cemal
jensenmann
« Reply #17 on: July 22, 2013, 04:32:50 PM »
Hi Cemal, will you revive the CL1?
Jens
Quote from: PRR
sahib
« Reply #18 on: July 23, 2013, 03:52:13 AM »
Hi Jens,
Naturally not the exact copy but the variation is a possibility.
sahib
Re: EQ ONE, 4 band Full Parametric Equaliser- by Total Audio Control
« Reply #19 on: October 08, 2014, 09:07:32 AM »
EQ ONE is now also available in Black.
The web site with online purchasing facility is also open.
Last post August 31, 2014, 04:22:25 AM
by Majestic12
Last post October 08, 2014, 09:22:17 AM
by sahib
Last post February 11, 2020, 04:17:33 PM
by helterbelter
Last post January 08, 2020, 08:45:57 PM
by Ricardus
