Thank you.
It is available.
I have split the kit into two parts.
Part 1: Essential Kit.This is the essential kit consisting of all of the design specific components, such as the metalwork, heatsinks, fuse holders etc. which I supply. Please note that this consists of two modules. One is the regulator module and the other one is the transformer module.
GBP 145.00.
Please note that for UK and EC purchases the VAT will be added. There is no VAT for the rest of the world.
The kit includes;
2 x Faceplate
2 x Backplate
2 x Stick-on facia
2 x Screen plate
1 x PCB
2 x Hex pillars
1 x Earth eyelet
4 x Fuse holder
1 x Mains Switch+ Cap
1 x Fuse booth
1 x Mains switch booth
1 x Heatsink for TL783
2 x Heatsink for LM317
3 x Thermal pad
3 x M3 Screw+bush set
4 x 2 Way terminal block 3.91mm pitch
6 x 2Way Terminal block 5mm pitch
3 x 2mm LED
2 x 1k5
1 x 4k7
20 x M3 Screw + shakeproof washer
Part 2: Active and passive components.These are the active and passive components which you can purchase locally or may even have in your stock already.
+48V RAIL1 x Bridge rectifier
2 x 1N4003
1 x 150R
1 x 5k1
1 x 1K trimmer
2 x 470uF100V
1 x 47uF 63V
2 x 100nF
1 x TL783
+ -16V/24 RAILS2 x Bridge rectifier
4 x 1N4003
2 x 240R
2 x 2k4
2 x 1k trimmer
2 x 4700uF 35/50V
2 x 1000uF 35V
2 x 100uF 35V
4 x 100nF
2 x LM317
4 x 20mm Fuse
The mains transformer.For my prototyping I have got the one in the pictures made by Avel Lindberg with 2 x 16V and 1 x 48V secondaries. It is encapsulated, with an internal mu metal band and interwinding electrostatic screen. One off price was GBP 45.00.
The mains switch.Panel plug:
Bulgin PX0429,
Rapid order code: 23-1215
Cable socket:
Bulgin PX0646
Rapid order code: 23-1210
I will start a build thread in the lab but in the mean time I have cobbled a series of photographs showing the assembly sequence. Link to the images.
http://www.robotica.co.uk/tac/500_psu_assembly.jpgHere are some general pictures.
The transformer shown is for only single slot power. The module can take a larger one to power upto 3 slots but anything above that requires additional slot as the transformer height will increase.
