Blackdawg
Re: 500 RACK / EQ ONE , MICPRE ONE, MICPRE THREE by Total Audio Control
« Reply #80 on: February 01, 2018, 05:05:19 PM »
Anyone heard from Cemal lately? I was in process of getting an order done via email for a custom rack mount PSU and a 11 slot rack. But haven't heard from him in weeks.
kante1603
« Reply #81 on: February 01, 2018, 06:33:01 PM »
Hello,
yes,he is posting here,just do a member search and look at his posts.
Personally my last contact with him was only two days ago.
Maybe wrong email adress?
Hope to have helped,
Udo.
Blackdawg
« Reply #82 on: February 05, 2018, 05:34:44 PM »
Hello,
Udo.
Hmm. Interesting.
I was using [email protected]
Had had several responses before I had to get in touch with Jeff at CAPI to ask about current draw for the ML2. Once I had the numbers i replied, but never heard back.
I'll just try again!
kante1603
« Reply #83 on: February 05, 2018, 07:11:43 PM »
Hmm. Interesting.
The adress is right,the same I use....maybe it went to the spam folder at Cemal's side?
And I know Cemal is very busy these days.
Please try again,if it fails again I can try to contact him for you if you want,though as said I use the same adress,but mine never went to the soam at least.
Please keep us posted,
best regards,
Udo.
Blackdawg
« Reply #84 on: February 05, 2018, 11:47:30 PM »
best regards,
Udo.
I got ahold of him today!
It was MY stupid email that was putting his lovely messages and updates on a custom rack mount PSU for me that his is putting together in the dang spam folder  >:(
Very excited to be getting a custom rack mount PSU and my first of 3 11 slot racks soon! 500 series mixer here we come!
kante1603
« Reply #85 on: February 06, 2018, 12:45:33 AM »
Good to hear,have fun,
best regards,
Udo.
12afael
Sahib, what screws use the lunchbox? it is 4 40 or it is metric?
thanks in advance
heavy metal is the law!!!
sahib
Thank you too.
On the first batch of 11 slot (511) all screws were 4-40.
On the second batch the module mounting screws, rear panel mounting screws and rack mounting bracket screws were all 4-40. Top and bottom panels to side panels mounting were M3 (countersink).
On the third batch that I have now the module mounting holes on the front are 4-40 but the rest is all M3.
The rest of the racks such as 501, 503 and 506 all have UNC 4-40 throughout.
Kind regards,
C
MatthewF
« Reply #88 on: August 03, 2018, 05:55:23 AM »
However, I can (and have done for a number of users) trim the floorbox case to make it shorter for a triple output. See attached image.
Hi Cemal,
Roughly what footprint does this PSU end up having with the case trimmed as described above? I'm trying to work out if I could squeeze it into my (very small) outboard rack!
Matthew
sahib
« Reply #89 on: August 03, 2018, 01:55:32 PM »
Hi Matthew,
We can have it at 200mm x 260mm x 70mm.  See attached image.  If you open it in paint and at 100%  it is half the original size (100mm x 130mm).
We can trim the length further down to about 220mm but we have to mount the single +48V board to the back of the front panel. You will obviously see four screw heads on the right hand side of the front panel.
However,  please note that this can only be for VPR (+ -16V and + 48V) version not 51x.
Kind regards,
Cemal
