psych60s said:
Hi folks
I'm currently working on the dbx 160 schematics for my thesis. The original 160.
Thesis? what grade level or degree is this for?
I can't figure out what exactly takes place in the sidechain circuit. The RMS outputs a positive signal to a first op amp (OA3) with a "level cal" pot. Is it a "detection sensitivity control"?
I could probably figure it out if I looked at it, but don't have a schematic handy.
Then the signal feeds a second op amp (OA 5). I have assumed that the threshold pot allows the user to set a value for a signal that will offset the RMS signal. But what happens if the RMS takes a negative value? Not sure about that
I am not psychic (and too lazy to search out a schematic) so I can't give you specific answers, but I can answer in general.
The side-chain for a compressor needs to generate a gain control voltage proportionate to signal level and relative to a compression threshold.
DBX VCAs generally respond to a linear voltage with a logarithmic (dB) gain change, so ideally the side chain wants to convert linear signal level changes to log domain so it can directly drive the VCA. While this detector output will generally always be a positive (or always negative) voltage that changes proportionately with signal level, by subtracting a fixed voltage from this representing the threshold, we can come up with + and - X dB gain change relative to the threshold.
RMS IMO is a bit of marketing hyperbole and I won't drag you off into the weeds with esoterica about "true RMS", so don't get hung up on that. The DBX detector performs a smoothed log conversion so that output voltage can be scaled and offset to generate +/- X dB of gain control manipulation. Generally 0V=0dB or unity gain for those generation VCAs. They may even have two gain control ports, so a negative voltage into the negative gain control port has the same effect as a positive voltage into the positive gain control port.
You can look up the data sheet for the VCA used in that design to find out what the gain law relationship is for the voltage changes sent to the VCA (X mV/dB). Knowing that you can work backwards to figure out what the opamps and trims in the side chain are doing.
The LED circuitry is also a mystery for me.
Thanks for helping me in that quest!
The led circuitry if displaying gain reduction it will simply look at the control voltage being sent the VCA. 0Vdc = unity gain or no compression, more voltage is more dB of gain reduction. Linear voltage change at the VCA will represent a linear number of dB.
