twin servo build questions
berkleystudios
VA, USA
looking at to to proto a few jensen twin servos since I have 6 jt-123-sl..... not what it calls for in the schematic but it has a low turns ratio and just a few db of less head room so i think ill be fine.
http://www.jensen-transformers.com/as/as083.pdf
but has anyone ever built one of these :
http://www.jensen-transformers.com/as/as082.pdf
ive never hear or used an ad797 and i amp not against using IC, in my circuits if it sounds great..
http://www.mouser.com/Search/Refine.aspx?Keyword=ad797
also anyone know any alternatives to this
http://www.jensen-transformers.com/datashts/oli2.pdf
AD797 is specified for +-15V of powe supply, with these voltages and an 1:1 out trasformer the headroom is not so great for an uncheap preamp.
So the 990s would be better because of the high voltage the require? Which in turn increases headroom?
A while back Presonus made the MP20 which was basically this exact same circuit built with Jensen transformers.  They used cheaper IC's than the AD797, for example 5534, and eventually even moved on to a cheaper transformer vendor than Jensen.
I have one I swapped the cheaper IC's out for the AD797 and I couldn't tell the difference although I was never good at detecting these types of differences.  I even tried phase inverting and nulling out AD797 channel 1 vs. unmodified channel 2 and if I remember correctly the resulting signal was high end like a HP filter...  However I will say this:  In non-music (audio-band) applications I've used the AD797 and it is as low noise as they say; it's a very high-performing op amp and you can certainly measure the difference between it and a cheaper IC.
If you search around this site there's a few threads about modifying the MP20, and you'll find a thread where they also indicate substitutes for each op amp in the circuit including the output IC and the insert IC that doesn't appear in that Jensen schematic.  You can also find out on the internet other sites where a guy named Jim Williams, who modified these things, suggests a list of IC's for the MP20.
Suggested substitutes are LT1357's or AD8597 or AD797 or OPA211 or OPA627 or OPA827 for the op amp in question.  Most of those you can get 4-6pcs of as free samples shipped to you if you go to the manufacturer's website and find the "free samples" section.
Indeed, headroom would increase. Let's say you go from +/-15 to +/-18V, you get about 2dB increase in headroom, going to +/-24 gets you another 3dB. Great.
What are you gonna do with this headroom? Most likely this will go to an A/D converter which has not enough input headroom to take advantage of it. The 797 is a wonderful design, the 990 too. Potentially, they may yield a marginally better noise figure than a 5534, a somewhat more extended HF response, and a slightly better THD performance. Provided you are an expert at laying out a PCB that avoids all the traps with capacitive and inductive coupling, ground current circulation and RFI/EMI protection.
No, I did not say this, but only to bring to the attention there is an headroom that is lower than the classic famous twin servo preamp.
Personally I prefer a twin servo preamp with 990's than AD797 inside but "de gustibus non disputandum est".
