JessJackson
This is to be true to the Ela M 251e Schematic and for as much of the circuit to be inside the PCB as possible.
Schematic Here: www.jessjackson.com/images/JKSNELAM/m251e.pdf
I am Hoping that Matador will jump on this with me and help to iron out the schematics and board layout. In principle I would love to see this project run parallel with matador and chungers amazing c12 project.
It will utilise the same body as C12 and utilise Chungers double mesh grill, with the hopes he will manufacture one with black mesh on rear side
I have drawn a rough pencil on envelope of the "Alpha" layout, I traced the edges of Matador V1.1A board and extended them down further to accommodate the T14 which can be mounted direct to the back board using small zip ties.
I have utilised the idea of surface mounted relays for pattern switching from Olivers Blackspade 251. This is where I got stuck though (as you can see from my drawing). I am not very familiar with relays and hoping that someone can finalise this layout. I have created an additional drawing with hookup points for you. www.jessjackson.com/images/JKSNELAM/JKSN_ELAM0.1norelay.jpg and here is how Oliver did it www.jessjackson.com/images/JKSNELAM/blackspaderelaywiring.jpg Here is the Relay Datasheet www.jessjackson.com/images/JKSNELAM/relaydatasheet.pdf or maybe now there is a more appropriate relay to use.
An alternate idea would be to place the cathode bias circuit on the back of the Tube PCB instead of the main board to keep runs shorter and to eliminate jumpers across boards.
This circuit could also be used with AC701 Miniature tube with just a few component value changes. (which is most likely the version I will be building first)
PSU: I have not touched this area yet. This is for you guys to brainstorm over. We will not be needing biasing but will be needing remote relay switching.
I am willing to finance the start up if need be.
I am going to throw this in Eagle in the mean time and see if i can get this relay circuit knocked up.
Let me know your thoughts.
J
J
